Skip to main content
Pumps & Systems Menu
Pumps & Systems
Pumps and Systems
Menu
Search
Subscribe
  • Topics
    • Pumps
    • Seals
    • Bearings
    • Valves
    • Motors & Drives
    • Instrumentation
  • The Latest
    • Browse by Issue
    • Podcasts
    • News
    • Events
    • Digital Edition
    • Columns
    • Departments
      • Back to Basics
      • Efficiency 101
      • HI Pump FAQs
      • Maintenance Minders
      • Market Analysis
      • Motors & Drives
      • Sealing Sense
      • Submersible Solutions
  • Learning Opportunities
    • White Papers & Case Studies
    • Webinars
    • Videos
    • Training
  • Connect
    • About Us
    • Contact Us
    • Advertise
    • Subscribe
Subscribe to Pumps & Systems
Subscribe Now and Get:
Breadcrumbs
You are here:
  1. Home
HI Pump FAQs
hi faqs
Is Stormwater Considered Wastewater?
Stormwater may require treatment similar to wastewater before being discharged to the environment.
hi faqs
Pumps
How is Predictive Maintenance Different Than Preventative Maintenance?
Preventative maintenance involves replacing or repairing something on a time-based interval, while predictive maintenance occurs as part of a condition monitoring program.
hi faqs
Pumps
How Are Pumps & Compressors Different?
Pumps and compressors look similar but are designed to handle different fluids.
hi faqs
Pumps
How Much Will Flow Rate Increase
if an Identical Pump Is Run in Parallel?
How the variability of flow rate increases based on the characteristics of the system curve.
hi faqs
Pumps
Are Positive Displacement Pumps Used in Power Generation?
These pumps can be used for chemical dosing, gas turbine misting and fuel oil and lubricants.
hi faqs
Pumps
How Does Hot Water Heating Work in HVAC Pumping Systems?
Focusing on primary-secondary arrangements within hot water heating distribution systems.
hi faqs
Pumps
What Pumps Are Used in Municipal Water Booster Stations?
Understanding the role and applications of water booster pump stations.
hi faqs
Pumps
Why Might Condensate Pumps in a Power Plant be Installed in a Suction Can?
Condensate pumps can manage low-pressure condensate, limit cavitation, and ensure optimal performance.
hi faqs
Pumps
What is the Difference Between Reciprocating Pumps & Rotary Pumps?
The meshing action of rotary pumps does not create the same level of pulsating flow as reciprocating pumps, and they do not require inlet and outlet check valves like reciprocating pumps.
hi faqs
Motors
How Does an Electric Motor Design Prevent Electrical Shorts?
Having a proper insulation system for an electric motor is important for protecting the motors from shorts and contaminants.
  • Load More
SubscribeSubscribe to HI Pump FAQs
Digital Partners
Trending
Preventing Water Utility Failures With ESA
How pairing telemetry with electrical signature analysis can help water utilities catch problems earlier.
Investing in Uptime: Breaking the Breakdown Cycle
A data-driven guide to achieving operational certainty and ending daily tech failures.
Pumps
Paddlewheel Flow Meters in Industrial Proportional Feed Systems
Exploring the benefits, uses and installation requirements of paddlewheel flow meters.
Pumps
Central Alabama Water’s Historic Cahaba Pumping Station
A look at a historic pump facility located in Birmingham, Alabama.
From Our Partners
Relay
Driving Safety & Uptime With Next-Gen Frontline Intelligence
Relay
Motor Reliability Impact on Carbon Capture
Learn about motor reliability basics, reducing energy waste, lowering material demands, minimizing unplanned downtime, and much more in this education webinar.
PdMA Corporation
Composite Bearings Improve Pump Reliability
How composite bearings can improve pump reliability and reduce wear in demanding applications.
Greene Tweed
Improving Process Efficiency With Clamp-On Flow Meters
Learn the seven ways clamp-on flow meters can help you save.
Fuji Electric
Browse Our Library
Topics
Pumps
Seals
Bearings
Valves
Motors and Drives
Instrumentation
News
Magazine
Events
Webinars
White Papers
Podcasts
Advertise
Customer Service
Subscribe Now!
Connect with Us
  • Home
  • Topics
    • Pumps
    • Seals
    • Bearings
    • Valves
    • Motors & Drives
    • Instrumentation
    • Pump Industry Insider
    • Compressors
    • Filters
    • Piping
  • Magazine
    • Browse by Issue
    • Digital Edition
    • Market Analysis
    • Columns
      • Amin Almasi
      • Gary Dyson
      • Jim Elsey
      • Joe Evans
      • Dominik Fry
      • Ray Hardee
      • William Livoti
      • Lev Nelik
    • Departments
      • Back to Basics
      • Efficiency Matters
      • Flow Meters
      • Motors & Drives
      • Sealing Sense
      • HI Pump FAQS
  • Resources
    • Digital Edition
    • Podcasts
    • From Our Partners
    • White Papers
    • Webinars
    • eBooks
    • Sponsored Videos
    • News
    • Events
    • Training
    • SWPA Training Center
    • Manufacturer Directory
  • Subscribe
  • Customer Service
  • About Us
    • Editorial
    • Advertise
    • Subscribe
    • Contact Us
    • Data Privacy
