Proven concepts together with new technologies battle the energy crisis.
Worldwide, countries have committed to significantly increase their share of electricity generated from renewable sources by 2020. Several renewable sources will contribute to meeting the expected demand for clean power. Most scenarios predict notable growth of electricity produced from wind, solar, biomass and geothermal sources. Of these, solar power has the highest theoretical potential because the sun provides the Earth with as much energy every hour as human civilization uses every year.
Power from the Sun
Converting solar energy into electricity requires a high level of technological expertise. Photovoltaic cells and concentrated solar power (CSP) systems are the most common technologies commercially used for solar-based electricity generation. Photovoltaic panels directly transform sunlight into electricity, whereas CSP systems concentrate sunlight to heat up a working fluid, which is used to operate a steam turbine to produce electricity. This fast-growing type of solar technology requires strong, direct solar radiation and is mostly used in large, centralized installations by utilities. In CSP plants, pumps are needed to circulate and store the working fluid on the solar island. On the power island, they are used for condensate extraction, feed water and cooling water circulation.
Tailored Pumps for Parabolic Trough Systems
The most widely used CSP technology is the parabolic trough system, in which long, trough-shaped mirrors concentrate sunlight onto thermally efficient receiver tubes located along the trough’s focal line. The first parabolic trough plants in the U.S. were commissioned in the Mojave Desert. These tubes are filled with a heat transfer fluid, such as thermal oil, which is heated from 285 C to 310 C. Horizontal, single-stage pumps are used to circulate this fluid through heat exchangers to produce superheated steam.
Solar Thermal Plant Gemasolar, property of Torresol Energy, was the first central tower to be built with molten salts for heat storage of 19.9 megawatts in Seville, Spain. The plant has storage capacity to produce electricity for 15 hours without sunlight.
The steam is converted to electrical energy in a conventional steam turbine generator or forms part of a combined steam and gas turbine cycle. The design of the pump’s shaft-sealing system is fundamental to ensure reliable operation and to avoid leakages of the hazardous and flammable thermal oil.
Highly Efficient Central-Tower Systems
The central-receiver technology allows higher temperatures and reaches higher efficiencies than parabolic trough plants. Circular arrays of heliostats concentrate sunlight onto a tower-mounted thermal receiver containing a heat transfer media that converts the solar energy into thermal energy to generate superheated steam. This steam is converted to electrical power through a conventional steam turbine. The heat transfer media can be either water/steam or molten salts. Central-tower systems concentrate heat at higher temperatures compared to other CSP systems, improving their conversion efficiency. The working temperature in this system is in the range of 500 C to 600 C, generating supercritical steam, which optimizes the thermal cycle’s efficiency.
Powering Through the Night
CSP generates power under direct sunlight, but the heat transfer process with thermal storage integrated into a CSP system ensures power generation during the night or during extended periods with cloud cover.
Molten salt circulation pump for parabolic trough concentrated solar power plantsA molten salt circulation pump for parabolic trough concentrated solar power plants
The majority of CSP plants are supplemented with natural gas-fired steam generation. This way, a plant can provide base-load power at all times, ensuring a high commercial value to the plant owner. Alternatively, thermal storage technology can allow CSP plants to meet base-load demand without the use of backup fuels. Molten salts are increasingly used today in CSP plants for heat storage or as primary heat transfer fluids because of their high specific heat capacity. When a thermal storage reservoir using molten salts is integrated into a CSP plant, electricity can be generated after sunset, with an extended operation period typically between six to eight hours.
High-Temperature Applications
In central-tower units with molten-salt heat storage, the fluids can reach temperatures up to 570 C, while in parabolic trough plants with molten-salt storage the temperatures are around 400 C. The design of pumps for these high-temperature applications requires extensive coordination between materials and plant technology and engineering. Vertical pumps mounted in tanks are preferred to simplify the molten-salt system. This eliminates the need for pump sumps, isolating valves, level instrumentation and associated heaters. It also reduces heat losses and allows the steam generator system to drain directly into the tanks. One pump for the circulation of molten salts in a parabolic trough system incorporates the hydraulics. It is a vertical, mixed-flow pump with high capacity and medium-to-high head units. It balances high efficiency, low submergence and net positive suction head (NPSH) considerations. The pump—used for cold and hot circulation and drainage and melting salt applications—reaches a maximum pressure of 16 bar and can operate up to a maximum temperature of 400 C.
Geothermal Power
Geothermal heat originates from the Earth’s consolidation of dust and gas over four billion years. The heat from the Earth’s core continuously flows outward and conducts to the surrounding layer of rock—the mantle. When temperatures and pressures become high enough, the mantle rock melts—becoming magma—and moves slowly up toward the earth’s crust, carrying the heat from below. Geothermal technologies use the energy stored in rock and in trapped vapors or liquids like water or brine. This energy can be used to generate electricity and provide heat. Power generation typically relies on geothermal resource temperatures greater than 100 C. Wells drilled into geothermal reservoirs bring these resources to the surface, generating electricity in geothermal power plants. Several geothermal plant technologies exist today, and the total global geothermal installed capacity is ~10.7 gigawatt per hour, resulting in 67.2 terrawatt per hour produced per year. Geothermal plant types include dry steam plants, in which superheated, pressurized steam is brought to the surface at high speeds and passed through a steam turbine to generate electricity. In flash steam plants, binary-cycle plants or combined flash/binary-cycle plants, the portion of the geothermal fluid that “flashes” to steam under reduced pressure is first converted to electricity with a backpressure steam turbine. The low-pressure steam exiting the backpressure turbine is condensed in a binary system. New technologies such as enhanced geothermal system (EGS) are being developed in Australia and the U.S.
Flash/binary-cycle geothermal plantFlash/binary-cycle geothermal plant
Flexible Energy Storage
The increasing share of electricity production from unpredictable renewable sources will change the way electrical grids are operated. With the global target of 20 percent of renewable power in the electricity mix by 2020, a large share of non-dispatchable and highly intermittent generation will lead to a need for large storage capacity. Several technologies—such as compressed air energy storage (CAES), e-car battery clusters, electrolysis-producing hydrogen and pumped hydro storage—are likely to contribute to meeting these future storage requirements. In a grid with a high share of installed wind and solar power, the power produced may temporarily exceed the current demand, resulting in power being extracted from the grid to stabilize its frequency. Pumped storage plants move water between reservoirs at different elevations, providing the most efficient means for large-scale grid energy storage. At times of low electrical demand, excess generation capacity is used to pump water into the higher reservoir. During higher demand, water is released back into the lower reservoir through a turbine, which improves the daily capacity factor of the generation system.
New Concept for Pumped Storage
Small, decentralized pump storage plants consisting of centrifugal pumps that are used as reverse running pumps will be able to provide a quick response, making them an essential component of a mixed power system. These storage plants will have an installed power that is lower than conventional pumped storage plants. However, several of these units balancing a larger wind or solar park will ensure optimal use of the renewable power generated. These new pump storage units will make use of excess renewable power possible without the need to significantly increase grid capacity. This will ensure that the renewable energy—the power output of which cannot be controlled by grid operators—will be smooth and dispatchable. To limit the global average temperature increase to 2 C, the share of electricity from renewable sources will grow significantly in the coming years.
