Nearly every commercial and industrial facility in the world pumps water. Pumping cold, lubricating water is normally straightforward and only requires standard materials seals and lower-pressure components. However, as water is heated, its properties drastically change, and the pump specifications should change as well. At 68 F, water has a specific gravity of 0.9982, a viscosity of 1 centipoise (cP) and a vapor pressure of about 0.3 pounds per square inch absolute (psia). At 176 F, water has a specific gravity of 0.9716, a viscosity of 0.355 cP and a vapor pressure of nearly 7 psia. Hot water is lighter, thinner and less lubricating and vaporizes to a greater degree. Weight and viscosity continue to decrease as the temperature increases. Above the sea level atmospheric boiling temperature of 212 F, the pressure to maintain water as a liquid increases dramatically (see Figure 1).
Higher temperatures reduce water’s lubricating effect and stress seal faces.
11/17/2014
Image 1. A new bronze pump inducer (left) is subjected to severe suction cavitation (right). [Image courtesy of Ceco Environmental, Met-Pro Global Pump Solutions (Dean Pump)]
A 316 stainless steel (SS) impeller has greater resistance to short periods of minor cavitation and should be considered when the difference between the NPSHA and NPSHR is less than 2 feet. However, this impeller cannot make up for inadequate NPSHA.
Many pump users do not realize that pump manufacturers’ NPSH details are not guaranteed unless an NPSH test is purchased for a specific operating condition. An NPSH test can confirm the performance and is strongly recommended when NPSHA is less than 4 feet greater than the pump’s NPSHR.
Figure 2. A flush line can effectively remove heat from the seal faces. [Image courtesy of Ceco Environmental, Met-Pro Global Pump Solutions (Dean Pump)]
For temperatures below 250 F, a flush line routed from the pump’s discharge to the flush connection in the seal gland plate can remove the heat generated by the seal faces. For temperatures above 250 F, a heat exchanger—either American National Standards Institute (ANSI) Plan 7321 (API Plan 21) or ANSI Plan 7323 (API Plan 23)—is highly recommended. The heat exchanger must reduce the seal area temperature to about 160 F. Without a cooled flush, the liquid film between the seal faces will begin to flash. As the seal faces begin to run dry, the seal prematurely fails.
The ANSI Plan 7321 (API Plan 21) includes a flush line from the pump discharge through a heat exchanger and into the connection of the seal gland plate to flush the seal faces. The flow is controlled through an orifice, with the size determined by the differential pressure produced by the pump.
Figure 3. The API Plan 21 (ANSI Plan 7321) [Image courtesy of Ceco Environmental, Met-Pro Global Pump Solutions (Dean Pump)]
The ANSI Plan 7323 (API Plan 23) is a flush line from the seal chamber through a heat exchanger and back into the seal flush connection on the gland. This plan requires that the mechanical seal be equipped with a pumping ring to circulate the water through the heat exchanger. The advantage is that the heat exchanger cools water from the seal chamber, which has already been cooled by the jacket. The disadvantage is that it requires a pumping ring, which works poorly at slow speeds.
Figure 4. The API Plan 23 (ANSI Plan 7323) [Image courtesy of Ceco Environmental, Met-Pro Global Pump Solutions (Dean Pump)]
The use of a minimum flow bushing positioned in the bottom of the seal chamber is recommended for both plans. This bushing separates the cooler water in the seal chamber from the hotter water in the pump casing and reduces the amount of flow from the seal chamber back into the pump. The bushing assembly is provided with a carbon bushing and 316 SS retainer, set screws and springs.
These seal plans should be furnished with a thermometer and a needle valve located in the flush line between the cooler and the flush connection on the gland. Cooling water flow to the seal should be in the range of ½ to 1 gallon per minute, and the temperature should be near 140 F. Cooling water flow to the heat exchanger should be between 7 and 15 gallons per minute, depending on the heat exchanger. The needle valve allows close regulation of the flow.
Figure 5. The minimum flow bushing limits the flow through the stuffing box. [Image courtesy of Ceco Environmental, Met-Pro Global Pump Solutions (Dean Pump)]
Adding a filter to ANSI Plan 7321 (API Plan 21) is highly desirable. A seal system consisting of a flush line from the pump discharge through a heat exchanger and then through a filter before returning to the flush connection in the seal gland plate offers an extra level of seal protection. This will filter out the welding slag, rust and scale common in most new hot water systems. It also cleans up an older system that may have scale. If the water has solids in solution, when cooled, they will precipitate or settle out and then filter in during flow. The seal system prevents solids from entering the seal chamber. These seal systems are furnished with a needle valve and thermometer.
Figure 6. The seal system includes ANSI Plan 7321 (API Plan 21) with a filter to remove particulate. [Image courtesy of Ceco Environmental, Met-Pro Global Pump Solutions (Dean Pump)]
