"How long will I be able to run my equipment before it has to be taken down for servicing?" is a question often asked when a buyer or user decides to purchase a new pump, agitator, or other type of rotating equipment. In some cases, a user may consider upgrading his existing pump to improve its reliability, capacity, efficiency or to bring it into compliance with federal or local emission regulations. The question will usually be the same. In many industrial pump applications, the seal is targeted as the most critical component. The seal usually will force removal of the pump from service because of an unacceptable leak rate or, in some cases, a level or pressure alarm. Although the seal is often blamed for the equipment failure, the real reasons are typically found in the operation and mechanical condition of the pump or the seals' environmental control system. Companies that have successfully implemented programs to improve Mean Time Between Repair (MTBR) are achieving three years or more average seal life, and consequently, have reduced the Life Cycle Cost (LCC) of their pump population. LCC projections for pump applications may vary widely based on the seal MTBR. In cases where the risk of failure is high, it is prudent to look for expert advice since errors in life estimates may have costly consequences. The key to any seal MTBR projection is to understand the factors that are most likely to drive the performance of the seal. Key Performance Indicators of a mechanical seal are normally the leak rate and power consumption.
12/17/2011
