In most U.S. states, running a 100-horsepower pump motor continuously for a year can rack up more than $40,000 in energy expenses. Improving efficiency in industrial pumping systems is one way to reduce these costs.
While variable frequency drive (VFD) technology can significantly increase system efficiency by controlling pump speed, not every application requires a VFD. To determine when to apply this technology, end users must conduct detailed calculations to verify the cost-effectiveness of using a VFD.
VFD Benefits
A VFD varies the speed of a three-phase, alternating current (AC) induction motor by adjusting the voltage and frequency of the motor's input power (see Image 1). Varying the speed of the motor improves efficiency by changing the pump's output to match actual pressure/flow requirements.
Any new or existing pump system with dynamic demand is a candidate for a VFD installation. If the pump often operates at a low flow rate, controlling motor speed with a VFD will result in much lower energy costs compared with running the motor at full speed and throttling its flow output with a control valve.
Because required pump motor power increases at a much faster rate than flow, pumping fluid faster than necessary can alter energy use significantly. In addition to reducing power consumption, a VFD can also help reduce mechanical wear, maintenance and related costs.
A VFD's ability to dramatically increase energy efficiency when used to control a centrifugal pump (see Image 2) is explained by the pump affinity laws.
Flow, Pressure2, Power3
The pump affinity laws are based on constant impeller diameter and varying speed. The premise of these laws is that, for a given pump with a fixed-diameter impeller, capacity is directly proportional to the speed (Equation 1), head is directly proportional to the square of the speed (Equation 2), and required power is directly proportional to the cube of the speed (Equation 3).
Where:
Flow is the volumetric flow rate (gallons per minute, cubic meters per hour, etc.).
RPM is the pump shaft rotational speed.
Pres is the pressure or head developed by the pump (psi or Pascal).
HP is the shaft power (horsepower).
Put simply, if pump speed decreases by 50 percent, then flow decreases to 50 percent, pressure decreases to 25 percent, and power consumption decreases to 12.5 percent. So the potential for energy savings increases as the demand for flow and corresponding pump speed decreases.
Calculating VFD Cost & Savings
To determine if a VFD is an efficient and cost-effective option for either a new or retrofit design, end users must first consider operating conditions and then calculate cost and energy savings by following 11 steps.
- Determine the pump's minimum to maximum pressure/flow (system) curve.
- Include alternate flow paths and related system curves for all operating modes.
- Specify the motor and pump to meet both minimum and maximum requirements on the pump performance curve.
- Estimate time the pump runs at low, medium and high flow rates.
- Estimate cost of kilowatt-hours (kWh) at each flow rate, including a 3-percent VFD loss.
- Translate these costs into yearly savings compared with running the pump at full speed.
- Add in any rebates from the utility for VFD installations.
- Add in reduced maintenance and longer pump life resulting from running the pump at lower speeds.
- Determine the cost of the VFD after installation.
- Add the cost of required supplementary equipment for power factor correction, noise filtering, etc.
- Compare costs and benefits to determine feasibility.
To evaluate potential cost savings, determine the operating speed range. Pumping system characteristics are defined by the system curve, which describes flow rate at a specific pressure. To determine the system curve, static and friction head must be known.
In an existing system, the system curve is calculated using data from pressure and flow measurements, control valve position and pump motor electric current measurements. If valves are used to add or remove equipment from the system flow path, then system curves must be created for each configuration. Once that is complete, compare the manufacturer's pump curve with the operating points on the system curve to determine the correct pump speed for each configuration.
To estimate potential savings from reduced power consumption, determine the amount of time the pump runs at the different operating points on the system curve. Hours spent operating at lower flow rates and head pressures along the system curve offer the greatest opportunities for cost savings. Variations in on-peak versus off-peak cost of electricity should also be considered.
Calculations should include pump efficiency and motor efficiency, as well as VFD losses of about 3 percent. When estimating potential cost savings, compare the operating costs of a fixed-speed pump against those of a variable speed pump for one year.
Installation & Control Considerations
The installation of a VFD may require additional components. Electromagnetic interference (EMI) filters, line/load reactors and radio frequency (RF) filters may be needed as part of the installation. Because a VFD is typically larger than the motor starter it will replace, a larger electrical enclosure may be needed. When retrofitting a VFD, the cost of new power cables to the inverter and VFD-rated cable to the motor must also be taken into account. Typical installed costs of VFD systems range from $200 to $500 per horsepower (HP).
Suppliers can assist users in selecting a VFD that is properly sized and that includes any necessary filters and reactors. If the application involves an existing three-phase motor, the motor may be used if the winding insulation rating is sufficient. The motor should have an insulation class rating of F or higher.
Compare the savings resulting from reduced power consumption with the cost of the installed VFD to determine if the return on investment is sufficient to justify the expense. Operating the pump and motor at lower speeds may lead to increased service life and reduced maintenance intervals, and these savings should be included in the calculations.
Application Example
Assume a centrifugal pump operating with a 15-HP, three-phase AC motor has across-the-line starting at 460 volts AC, 60 Hertz. The pump typically turns at a constant speed of 1,750 rpm, consumes 10 HP and discharges 200 gallons per minute (GPM) with a head of 120 feet. A throttling valve is used to vary pump output from 200 to 100 GPM.
A review of the system indicates that the pump normally operates with the throttling valve positioned to limit pump discharge to 100 GPM. The reduced flow rate represents 50 percent of the pump capacity, occurring 90 percent of the time.
Based on the affinity law, pump capacity is directly proportional to pump speed, so a reduction in speed to 50 percent will achieve an identical reduction in capacity/flow rate (see Equation 4).
Table 1 shows that, according to the pump affinity laws, reducing the flow by 50 percent cuts the pump head pressure to 25 percent of rating. A readily available VFD energy savings calculator can help determine the potential cost savings achieved by using a VFD.
In this example, based on 4,160 hours of annual run time and a cost of $0.12 per kWh, annual energy consumption drops from 21 to 8 megawatt-hours when the pump is controlled with a VFD as opposed to the original control method using a throttling valve.
This represents an annual savings of $1,589 or 62.4 percent. With an estimated installed cost of $4,000 \uc0\u8232 for a 15-HP VFD, the payback period is 2.5 years.
Lower Costs & Simplicity
As the cost of electricity continues to rise, the need to reduce energy consumption becomes even more important. As demonstrated by the pump affinity laws, operating a pump at lower speeds can significantly reduce energy consumption.
Compared with operating a pump at full speed with a throttling valve, using a VFD to run a pump at the desired lower speed usually is a more efficient option. The VFD reduces energy consumption, eliminates the need for a throttling valve, simplifies piping design and installation, and cuts maintenance costs.
