HI Pump FAQs
Hydraulic Institute
09/16/2016
Q. What mechanical seal designs are recommended for wastewater application pumps? A.In wastewater, two seal arrangements are commonly used: single seal and dual-pressurized (double) seal. Single seal designs, shown in Figure C.2, are normally either a stationary pusher seal with the springs isolated from the process fluid or a rotating elastomeric bellows seal with a large single coil spring wetted by the product.
![Single cartridge pusher seal](/sites/default/files/0916/Figure-C_2-Single-cartridge-pusher-seal-TONED.jpg)
![Split mechanical seal](/sites/default/files/0916/Figure-C_4-Split-mechanical-seal-TONED.jpg)
- They are hydraulically balanced and provide maximum interchangeability in pumps and other equipment without equipment modification.
- They eliminate sleeve wear and minimize power consumption compared with packing.
- They have a wide operating window, from vacuum to positive pressure.
- They can be installed without sleeve or shaft replacement, even if the pump was previously packed.
- The springs are typically a nonclogging design or are located outside the process fluid, which prevents them from clogging.
- They eliminate excessive leakages that lead to bearing failures and corrosion issues.
- Large pumps benefit from split seals by saving equipment teardown for initial installation or seal replacement.
- They reduce maintenance and operating costs for large pumps through reduced flush requirements and repair costs.
- While the initial cost of split seals can be slightly higher than nonsplit component or cartridge seals, the overall life-cycle costs (LCC) can be less. The savings associated with split seals are achieved by not having to remove the pump or realign the equipment for seal repair.
![Elastomeric bellows seal](/sites/default/files/0916/Figure-C_3-Elastomer-bellows-seal-TONED.jpg)
![Service class chart](/sites/default/files/0916/Figure-12_3_4_2a.jpg)
See other HI Pump FAQs articles here.
