In my experience, few plant personnel are concerned with how a pump is running until after it breaks down. When the whole plant unexpectedly shuts down, then the pump gets attention. By simply monitoring pump pressures, however, users can avoid this problem. The equipment will usually tell you there is an issue long before the failure. You just need to know how to watch and listen for the signals. To quote a good friend and fellow pump expert, Larry Bachus, "Would you want to drive a car that didn't have a dashboard?" The Occupational Safety and Health Administration (OSHA) reports that most workforce accidents occur when a plant is in an emergency (unscheduled) situation. If you want to increase reliability and reduce the high costs and safety risks associated with emergency shutdowns, adding gauges and managing the data are simple and inexpensive first steps.
Gauges
Gauges will measure pump performance and display the differential pressure across the pump. That information, in conjunction with knowledge of the pump and system curves, will provide plenty of details about the health of the pump and system. The differential pressure is key to knowing where the pump is on its operating curve. Converting the differential pressure to head will show a location on the curve. Convert pressure to head by multiplying the differential pressure by 2.31 and dividing that product by the specific gravity. Another related issue that I witness often is originally installed gauges that are missing, broken, ignored, not calibrated or compensated, and/or not logged. The gauge by itself cannot save you from pump failure and consequential plant shutdown. A trained person must read the gauge regularly and record the data. Some systems with pressure transducers do this automatically. At that point, however, the data alone is still not useful information. The recording operator must be trained to know the process dynamics and be able to determine if the reading is in or out of specification.Pump Curves
The pump will operate at the point on its curve where it is intersected by the system curve. Note that this is usually a changing dynamic, not a fixed point. As the pump curve changes with impeller size, speed and wear (clearances open up), the system curve changes with wear, process control changes, corrosion and/or marine growth buildup. Figure 1 shows that pump curves change with size, speed and wear (curves A and B). The system curve(s) (curves X and Y) also changes with wear, corrosion, buildup (such as fouling or marine growth) and the position of system management components. Where the pump operates over time is not a constant or fixed point. Where the pump operates on its curve affects the health of the pump.
