People have always had the need to treat the water they consume and use for cooking, bathing and washing items in their homes, including laundry and cookware. They have also needed to find ways to properly treat and dispose of the water that has been fouled through the course of its use, most commonly during industrial production activities. This need helped the water/wastewater treatment industry grow to billions in revenue in the United States and to an annual rate of growth anywhere between 3% and 4.5%.
When people hear the phrase water treatment, however, the first thought that may come to mind is taking water that will be used in domestic settings and removing any impurities, making it safe to drink, cook with, bathe in and wash clothes with; in other words, municipal water treatment. However, from a broader perspective, the term water treatment can have several different meanings.
In industrial applications, for instance, water can be taken from a nearby river and used for boiler or cooling-tower makeups. In the oilfield, water that is used or produced during the drilling and recovery process can be treated and sold to farmers for use in field-irrigation activities.
This article will illustrate how an integrated wastewater treatment system, with many different types of equipment working together (specifically metering and peristaltic [hose] pumps and polymer makedown systems) can be used in a straight-line treatment process. This will deliver the most cost-effective and efficient way to treat industrial wastewater, while making it safe for disposal or reuse in any number of additional activities.
The Challenge
Most of the water used or produced in industrial applications contains some level of solid particles. It goes without saying these particles should not be consumed, but particle-laden water also cannot be used, for example, in a boiler that provides steam to a turbine during power generation, lest the turbine become fouled and damaged.
Recognizing the presence of particulates in water and successfully removing them, however, are two different things. Some of the particles, which can be anything from bacteria and plant material to dirt or minuscule pieces of crushed stone, are so small their response to gravity is low. They do not fall through water at a consistent rate because their mass is so small and not impacted by gravity. This means it may take hours, days or even weeks for the particles to settle as little as a foot. This is an unacceptable and unpredictable settling rate for a water or wastewater treatment system, so the particles need some help in settling or clumping.
To speed along the settling or clumping process, the water treatment facility must turn to the introduction of a coagulant or flocculant that helps the tiny particles clump together in a mass that is called a “floc,” which is easier to remove. Two of the more popular types of coagulants/flocculants used in water/wastewater treatment are:
Alum – A more economical way to say hydrated potassium aluminum sulfate, alum has been used since Roman times to aid in the purification of drinking and industrial-process water. Alum coaxes negatively charged colloidal particles to clump together so they will be able to be more easily removed from settling basins.
Ferric chloride – Another name for iron (III) chloride, ferric chloride undergoes hydrolysis when dissolved in water, which gives it the ability to sufficiently form suspended solid particles into flocs.
While quite effective in creating flocs, the flocs that are formed by alum and ferric chloride are held together rather loosely, which means they can break apart if agitated as they settle in the clarifier or settling basin. Eliminating this breakup potential requires the introduction of a polymer solution that helps form more efficient flocs. The polymer takes the neutralized solid particle clumps and binds them together more tightly. Removing the sludge from the water requires a pump that can run dry and will not be bothered by abrasive materials. It requires a pump that has the capability to take whatever flows into it—no matter its makeup—and deliver it out the discharge side in that same form.
Industrial water or wastewater treatment, then, is a three-stage process that must work together: initial floc formation with alum and ferric chloride, clump-strengthening with polymer and removal and disposal of the sludge. A wide variety of industries use untold millions of gallons of water and produce untold millions of gallons of wastewater every day. Properly handling and disposing (or reusing) of this wastewater requires several stages that must work together seamlessly, from alum and ferric chloride introduction, to polymer injection, to sludge removal. Each stage requires a different type of technology, which can often have the wastewater plant operator moving in many different directions to identify a solution.
