As Andres Suazo discussed in an article last month (Pumps & Systems, May 2015), today's industrial engineers have many ways to monitor and control remote pumps, including wired Ethernet, wireless cellular systems and proprietary wireless systems. This follow-up article takes a closer look at proprietary wireless systems. It will highlight how one public water utility in Germany used a wireless system to monitor tank levels and eliminate costly cabling. Wireless technology continues to evolve. Many manufacturers offer license-free proprietary wireless radios. This technology has been widely accepted, thanks to its reliable performance. Typical applications include wireless I/O (replacing wired connections between field devices and control systems) or data radios (replacing wired serial connections between intelligent devices).
License-Free Proprietary Wireless Technology
In 1985, the Federal Communications Commission (FCC) made several frequency bands available without a license under certain conditions. These industrial, scientific and medical (ISM) license-free frequencies would eventually be adopted by industrial radio manufacturers and find their way into industrial applications. Proprietary wireless modules use ISM bands. The frequencies in the U.S. are as follows:- 900 MHz (902 to 928 MHz)
- 2.4 GHz (2.4 to 2.484 GHz)
- 5 GHz (5.18 to 5.825 GHz, but not continuous)
Water Utility Networking
Lage, Germany, relies on a 233-mile network of water pipes to supply drinking water to 9,000 homes in and around the town. The annual demand is more than 380 million gallons. More than 18 springs supply the water, which is then pumped to three water treatment plants. Eight elevated towers store the drinking water. Three pressure boosting stations maintain the constant pressure necessary for the network. Computers in the central control room in Lage are networked to monitor most of the elevated towers and pump stations. The computers indicate the operating states, document the inflows and outflows, and statistically evaluate the amount of water pumped. The system automatically activates the pumps in the pressure boosting stations if the level is not met. If a fault occurs, the system alerts the on-call personnel or notifies external technicians. One of the elevated towers supplies approximately 1,200 residents of two local communities with drinking water. Before the system was automated, an employee had to go to the tower every day to manually read the level. Now, the system constantly monitors the digital signal from the level sensor in the elevated tower. If an error occurs, personnel in the central control room receive immediate notification so they can respond as quickly as possible. Transmitting the signal to the central control room from this remote location was particularly difficult, as the elevated tank is at the edge of a forest and is connected neither to the central control room nor power from the grid. The next station that can be used to transfer the value—a pressure boosting station connected to the central control room—is approximately 1,000 yards away (see Image 1).Solution Advantages
Public water utility employees in Lage chose a wireless system with a stand-alone solar power system to provide an independent power supply. By selecting both a wireless I/O signal radio system and a stand-alone solar power system, employees were able to eliminate the need to lay any cable. This saved between $25 and $35 per foot for digging trenches and routing cables. "We were won over not only by the lower costs compared with the cable solution but also by the simple commissioning and reliable operation," said Erhard Heissenberg, who is responsible for water recovery and supply at Lage public services.
