12/17/2011
Pumps & Systems, May 2007
How to Talk to Managers
Most financial decisions of any consequence at your facility are made by managers; Plant Managers, Project Managers, Operations Managers, Financial Managers, etc. If you want to sell your ideas and recommendations to these decision makers, you must learn to talk to them in the financial language they understand. The most common financial tools for evaluating investment options are net present value, NPV, Payback, and internal rate of return, IRR. NPV, Payback, and IRR are all acceptable financial measures to aid in the making of economic decisions. NPV returns a dollar value, Payback returns a duration until investment is recouped, while IRR returns a rate of return value for the investment. All other factors, such as personal preferences and initial cost, should be secondary to these three financial parameters throughout the pump selection process. This article will address only NPV.A Simple NPV Example
Let's consider a simple example. Let's assume you are considering purchasing a new air conditioning unit for $8000. The seller of the unit predicts you will save about $200 per month due to the improvement in efficiency. He also estimates you'll save about $1000 per year in maintenance for the next five years, resulting in a $3400 per year saving or cost avoidance. This begs the question: Does this investment make good economic sense? To determine this, you have to answer a few questions and make a few assumptions:- What is the project life? 5, 10, 20 years
- What is the rate of return that I can get for a zero risk investment in lieu of the purchase? 4%, 6%, 8%
- What is an acceptable NPV?
Pump Life Cycle Cost (LCC) Evaluations:
When evaluating pump selections for your facility, you should use similar financial evaluations. However, industrial decision making includes additional factors such as taxes, depreciation, spare part storage costs, etc. We call the cash flow analysis of the initial pump costs, energy costs, and maintenance costs "life cycle cost" analysis. This detailed economic evaluation, which typically returns the net present value of a pump under consideration, is the most important pump calculation you will ever make. To properly evaluate a single or group of pumps, you need to know:-
Cost of the pumps
Cost of installation
Annual energy costs
Annual cost of maintenance
Any other recurring cost
Discount rate ( Risk Free Rate)
Project life
Corporate tax rate
A Real-World Pump Example
In the following table, you will find the results of an analysis from the PumpCalcs.com expert calculator entitled, "Life Cycle Cost Analysis." By inspection, you will see that Pump #1 has a lower purchase price, but requires more horsepower and is less reliable that Pump #2. (Note that I assumed Pump #2 would have a 48 month mean time between repairs (MTBR) due to its superior design as compared to the 24 month MTBR for Pump #1.) Also included in this analysis is the effect of a more efficient motor on Pump #2.
Breaking Down the Costs
Let's look at the life cycle costs of Pump #2 in more detail. By rerunning the Barringer analysis to find the NPV numbers for pump costs, pump installation costs, energy costs, and repair costs separately, we can determine, on a percentage basis, the relative value of each component. A summary of Pump #2 can be found in the figure below.
