Vertical multistage (VMS) pumps have become popular because they provide increased pumping efficiency along with energy savings. With a variety of nominal flow ratings and the benefit of multistaging, the technology features a wide range of discharge pressures and pump horsepower ratings to cover a multitude of hydraulic applications such as water supply and pressure boosting; heating, ventilation and air conditioning; light industrial; irrigation and agriculture; and water treatment. Combine one of these fixed-speed pumps with a variable frequency drive (VFD) controller, and the affinity laws will provide even more pump versatility. There is, however, a misconception that a VFD allows the VMS pump to function properly without having to appropriately size it according to the application. While pump sizing is key, users should consider a few other tips to ensure proper safeguards.
Case History
Examining a common example of how VMS pumps can be misused and overloaded helps demonstrate the specific effect pump sizing can have in the field. A series of identical VMS pumps, each controlled by a separate VFD and all installed at a single site, had experienced premature motor failures on a number of the pumps. None of the motors had been taken to a motor shop for evaluation. The units purchased were small, 1-horsepower (hp), 2-stage pumps with three-phase, standard-efficient, open drip-proof motors with Class B insulation, capable of 25 gallons per minute (gpm). The first question asked about these 460-volt VFDs was how far they were located from the motors they controlled and whether there was an output filter included with each VFD. The response was that the pumps were about 50 to 60 feet away from their drives, and no filtering was in place.
Finding the Cause
The pumps were taking water on a flooded-suction basis from an open-to-atmosphere inlet vessel that collected washdown from a manufacturing process. The pumps transferred the water up into large, low-pressure media filters. The liquid-level transducer tied to the VFD monitored the inlet vessel fluid height and adjusted the pump speed to maintain a specific level in that vessel. On the pump's discharge side, there was a small elevation change up to the filter inlet and no obvious friction loss. The filters offered little backpressure to the pump flow, even when they were fully loaded just before backwashing.
Eliminating the Problem
With the transducer and proportional integral-derivative (PID) controller loop set up on the suction side to keep the inlet vessel at a steady level, the pump could run at up to full speed to move the correct amount of water. With little to no backpressure on the pump's discharge side, the 25-gpm pump tried to output 50-plus gpm and overloaded the motor in the process. Had the throttling valve been properly set up at startup—which would have required an amp clamp measurement while running the pump at full speed—these incorrectly sized pumps could have operated on their curve. Another more "tamper-proof" throttling option would be installing a fixed orifice flow control valve on the pump discharge line to prevent it from going beyond its recommended operating range. If the VFD was set up to hold back or fold back the motor's revolutions per minute (rpm) when it detected slight prolonged overloading, the amps could have been maintained below the motor nameplate rating so the motor would run cooler and the windings last longer. Sizing the pump to properly fit an application is critical to avoid problems. It is important to look toward the center of the VMS pump curve to find the best efficiency point and range and to try to operate within that range. When possible, try to establish safeguards against changing a system that has been designed. It is not uncommon for a new employee to open or close a valve, for example, so keep that in mind before the installation to protect against motor failure. VMS pumps provide flexibility to meet pumping requirements for many applications. Take the time before installation to evaluate the previously noted details, and the result should be a successfully applied, long-lasting, productive and efficient pump.9 Tips To Avoid VMS Motor Failure
- Know your max flow and head requirements, and then properly size your VMS pump according to your application pre-installation.
- A VFD does not give your VMS pump supernatural abilities. Overloading can still occur if the pump is not sized properly. Ensure your overloads are set properly to take the pump offline should a problem develop.
- When setting up a pump system to be controlled by a VFD, follow the VFD manufacturer's guidelines concerning the need for output filtering to reduce damage to the motor insulation system from voltage spikes. Using a motor with a Class F or H insulation system would give the motor a higher temperature rise rating and ensure the insulation holds up better under warmer operating conditions.
- Properly set up the throttling valve at pump startup if the transducer and PID feedback are not monitoring the pump’s discharge side.
- One option is to install a fixed orifice flow control valve on the pump discharge line to prevent it from going beyond its recommended operating range.
- Follow the manufacturer owner's manual closely and test repeatedly.
- To achieve results backed by proper testing, partner with one manufacturer (for both the VMS pump and the VFD) that tests the products working together and can prove their performance.
- When buying your VMS and VFD, choose a manufacturer with a proven history of on-site product support to ensure future challenges or questions are quickly resolved and maximum performance is continued.
- When using a VFD on any pump, including a VMS pump, bearing failure from VFD-induced shaft voltage and the resulting bearing currents can be prevented with the use of ground shaft rings, or it can be reduced significantly with the use of a dv/dt filter.
