An easy way to calculate cooling requirements for electronics within an industrial enclosure.
Sponsored by: Pfannenberg USA
Variable frequency drives (VFDs), programmable logic controllers (PLCs) and similar electronics are critical to pump operation. They generate heat, especially when dealing with high loads or frequent starts and stops. The basic challenge of electronics cooling comes from the fact that VFDs and other critical electronics usually need to be placed in an enclosure to protect them from the immediate environment, and paradoxically, these enclosures trap heat, which necessitates protection from overheating. In this white paper, learn about the different enclosure cooling methods and a simple formula to calculate the cooling requirements for your electronics.
