![Ruthman White Paper](/sites/default/files/2020-10/Ruthman-EBook-image.jpg)
Eliminate mechanical seal failure headaches, downtime, and cost
Sponsored by: Ruthman
Leaky pumps are a common ongoing problem for plant maintenance engineers. Depending on severity of the leak, the problems they cause can range from loss of costly process fluid, to slip and fall hazards, to risk of OSHA and EPA fines. Remedying leaky pump conditions mean downtime and cost.
This white paper explores the root cause of most leaking pumps: faulty sealing methods. It explains the various seal options, how they work and why they fail. Finally, it presents an alternative that eliminates leaks completely.
Download this white paper to learn how seal-free pumps work to end leaks, and how easy it is to retrofit your process.
Fill out the form on this page to download the white paper.
![Ruthman Ruthman](/sites/default/files/Ruthman-logo-348x100.png)
