Part One
Last month, we discussed thermal radiation and material properties and the thermal nature of materials. We also looked at the emissivity of real objects using a stainless steel block. This month, we will discuss other characteristics demonstrated by the steel block example.
Emissivity, the Variable Variable
Using our steel block example from last month, we will discuss another significant phenomena. We will take our unpainted metal block and drill three holes part way into the body. All three holes are 1/8-in diameter. The first is 1/8-in deep, the second is ¼-in deep and the third is 3/8-in deep. Bake the block for another three hours, then remove the block and observe it again with the camera (see Figure IR4).
Figure IR4Figure IR4
Interestingly, the hot block surface appears to be about 84-deg F, and now appears to have three hot spots. The 1/8-in deep hole appears to be 106-deg F. The 1/4-in deep hole appears to be 112-deg F; and the 3/8-in deep hole appears to be 125-deg F.
We know that the metal block is actually about 175-deg F (measured by a thermocouple), and the surface finish is uniform and has an emissivity of approximately 0.12. The reason the temperature appears to be higher in the holes is that a hole in a body enhances the emissivity. The greater the depth/diameter ratio of the hole, the greater the emissivity enhancement. By adjusting the emissivity on the thermal imager to match the actual temperature at each hole, we find that the emissivity appears to be 0.25 for the 1/8-in deep hole. The emissivity of the 1/4-in deep hole appears to be 0.35, and the 3/8-in deep hole appears to have an emissivity of 0.45.
We need another piece of electrical equipment to see why this is an extremely important effect.
Figure 5Figure 5. Three-phase power disconnect
Figure IR5. Corresponding thermal image.
Emissivity and Electrical Equipment
Figures 5 and IR5 show another power disconnect with the conductors bolted in place using allen head bolts. The corresponding infrared image shows a hot connection on the middle phase. Notice the apparent hot spot in the hot allen socket head. The well of Figure IR5the bolt head appears hotter primarily because the well illustrates the blackbody effect of a hole.
In manufacturing processes, steel or aluminum rolls are often used to heat or cool a material such as in paper or plastic film processing. These rolls are usually polished metal surfaces, and it is important to understand the thermal profile since the manufacturing process depends on thermal uniformity across the rolls. The temperature of these rolls can be difficult to measure with a thermal imager because they have low emissivities. However, there are often points where the material passes between two rolls. The tangent point between two rolls also tends to simulate the blackbody effect, allowing for effective temperature measurement in an otherwise difficult situation.
This effect is illustrated in common electrical equipment as well (see Figure 6). In this case, we have another power disconnect with knife blade switches. This type of switch utilizes shiny metal blades, and the proximity of the blades with narrow gaps simulates the blackbody effect for greatly improved effective emissivity.
The important message here is to develop your understanding of apparent and actual temperature measurements. Actual temperature measurement requires an intimate understanding of physics, heat transfer and characteristics of materials.
Figure 6Figure 6. Power disconnect with knife blade connectors.
Figure IR6. Corresponding thermal image.
Qualitative Versus Quantitative Infrared Thermography
Emissivity difficulties are not a barrier to effectively using infrared thermography for predictive maintenance (PdM). ASTM standards exist to guide thermographic PdM inspections. These standards describe the use of thermal imagers for qualitative and quantitative infrared inspections.
Figure IR6
Quantitative infrared inspections require determining each component's emissivity to make accurate temperature measurements possible. This practice may not always be necessary for routine inspections, unless the exact temperature value is needed for long term tracing. Qualitative methods, in contrast, allow you to leave the emissivity at 1.0 and evaluate the equipment on a relative basis. Has it changed, or is it different? The basis for qualitative evaluation is comparing similar equipment under similar loads.
In Figures 1 and IR1 (reprinted here from Part One), you can see that there is little value to be gained in spending time estimating or debating the emissivity of the various parts in the power disconnect. The value is in understanding that phase A is hotter than phase B and C. In addition to realizing that a phase is hotter, it is essential to measure the load of the three phases. Greater electrical load inherently means more heat is present.
            P = I2 R
Where:
P =       Power in watts (heat)
I  =       Current in amps
R =      Resistance in ohms
Figure 1Figure 1
Figure IR1
Figure IR1
First Rule of Infrared Thermography: Comparable Equipment Under Comparable Loads
The first rule of thermography in predictive maintenance is to compare comparable equipment under comparable loads. In electrical power distribution, comparable equipment is usually the easy part since each electrical phase is generally similar in materials to the phase next to it. Load is a different matter. Figure 7 illustrates an electrician measuring the electrical load.
Just observing that a hot spot exists does not indicate a problem. Electrical components can be appropriately hot for the electrical load and conditions. If you measure the loads, you can determine if the presence of a thermal anomaly indicates a problem. Thermal imagers do not identify thermal problems-trained, knowledgeable, qualified people make educated assessments of equipment. This leads to real value in preventive maintenance and reduced frequency of equipment breakdowns.
Summary
Predictive maintenance with a thermal imager can be effectively performed by utilizing qualitative analysis of equipment. Qualitative techniques allow the emissivity setting on the thermal imager to remain at 1.0 and apparent temperatures be used for comparisons between similar equipment under similar load. With basic training, most technicians can reliably perform qualitative analysis.
Quantitative infrared analysis requires a deeper understanding of thermal theory and application to be truly effective. It refers to the attempt to measure actual temperatures of materials using infrared thermography. Actual temperature measurement involves more than simply adjusting for emissivity. Total incident radiance requires dealing with the effect of reflection and transmission in addition to emissivity.
Today's thermal imagers are becoming increasingly affordable and easy to use. But what does easy mean? The practice of infrared thermography looks straightforward and simple, but there are tricks. It is much like most endeavors in life: the more you learn, the more you discover there is more to learn.
References:
  • The American Society for Nondestructive Testing publishes the Nondestructive Testing Handbook, 3rd Edition, Volume 3, Infrared and Thermal Testing. This work is referenced as the general source for the equations and technical data for the content of this article series.
  • Qualitative and quantitative infrared thermography are referenced to ASTM E1934 Standard Guide to Inspecting Electrical and Mechanical Equipment Using Infrared Thermography. This industry consensus document describes the recommended procedures for conducting infrared inspections for predictive maintenance.
Safety note: Infrared thermography is often used to inspect electrical power distribution equipment. This article discusses the technical aspects of performing infrared analysis, especially as it relates to electrical equipment predictive maintenance. All persons working on or around energized electrical equipment should consult NFPA 70E for OSHA safety requirements.
Click here for additional information.
Pumps & Systems, February 2009
