More than 1 billion people live in arid regions with little to no access to freshwater. Two-thirds of Earth is covered in water, but 97 percent of this water is seawater. Land-based freshwater sources, from the developing world to more industrialized countries, have been nearly depleted as populations grow and demand increases. Seawater desalination can address the world's demand for consumable water. For many countries, desalination is the only source of potable water. However, the equipment in the desalination process—from the pump to the motor—consumes vast amounts of energy. Equipment efficiency is the key consideration in desalination plant design and operation because it ultimately determines the final cost of the water. The core hydraulic system of a reverse osmosis (RO) plant is the high-pressure pump. This pump pushes pretreated seawater through a membrane at a pressure that exceeds osmotic pressure. Because of the higher power requirements, the pump accounts for most of the facility\'92s energy consumption and determines the system's overall efficiency. A new technology combining a high-pressure pump, an electric drive, a booster pump and an energy-recovery device can save up to 75 percent of energy costs in reverse osmosis (RO) desalination plants.
How It Works
The combined pumping unit includes a lubricated free axial piston pump and an axial piston motor as an energy recovery device. The piston pump produces the water flow to the RO membrane. This flow depends on the engine speed and the pump's displacement volume. he axial piston pump and the axial piston motor are connected through an axle driving shaft. When the redirected brine concentrate flows through the piston motor, it supports the electromotor in powering the piston pump. The relation between the displacement volume of the piston pump and the piston motor is defined by the recovery rate. The operating pressure will be adjusted automatically by the membranes.Energy Recovery
The combined pumping unit receives pretreated seawater with a concentration of about 40,000 parts per million (ppm) from a feed pump. The pressure center raises the seawater pressure from 36 to 1,015 psi and transfers the water into the RO membrane. The membrane separates the brine from the water to produce permeate.
