Most industrial centrifugal pumps carry a significant capital equipment value. Maintaining them to run close to their best efficiency point (BEP) saves in downtime, repair costs, and overall power consumption. Proactive maintenance extends the useful life of a pump, reduces breakdowns, increases longevity and reliability, and extends the mean time between failure. When a pump operates outside its BEP, flow separation and turbulence occur. A common result of turbulence is cavitation, which can cause damage such as erosion and vibration. Corrosion and chemical attack also impact pump performance and longevity. All of these factors can cause a pump to fail prematurely and depreciate at an accelerated rate. While damaged pump components can be replaced, the capital costs associated with replacement and spare parts inventory can be cost prohibitive. The most cost effective and realistic solution is protecting and/or renewing damaged pump surfaces. Damage to pump surfaces is highly predictable, occurring most often on specific parts such as casings and impellers. To rebuild damaged equipment and provide ongoing protection, maintenance professionals are turning to polymer composite materials, a new category of aftermarket products that offer durability rivaling that of metal coatings. Three main categories of polymer composite materials for equipment repair are 1) metal repair materials, 2) wear resistant coatings, and 3) chemically resistant coatings. Often used together to correct operating problems related to wear, these materials make repairing pumps significantly more cost effective than replacement.
12/17/2011
