During my introduction to a piping system fundamentals course at an open-pit copper mine and mill in the southwestern U.S., I stressed the importance of understanding how the individual items of a piping system work together. I then went around the room and asked the attendees what they did at the facility and what they hoped to get out of the course. Each attendee had a specific topic of interest, but the dewatering engineer said his goal was to improve the operation of the dewatering pumps. Knowing that the mine was in the desert, I asked him how big the pumps were. He mentioned they were mounted on a semi-trailer so they could be moved around the mine, and they were equipped with a second semi for the diesel electric power supply. Even though the operation was in the desert, the rainfall would run off the ground and result in flash floods that could quickly collect in the mine and cause a disruption in production During the training when I discussed system static head, I emphasized that the static head of the dewatering system amounted to the difference in elevation between the water level at the bottom of the mine and the end of the discharge piping. When we covered the material on pipeline sizing, the dewatering engineer asked why we needed to perform this calculation. He said his rule of thumb was to size the discharge pipe to that of the pump's discharge flange. For example, if the pump's discharge nozzle was 6 inches, he would use a 6-inch pipe for his discharge header. This column will discuss why this rule of thumb may be costly.
The System
A piping system is made of three elements: the pump elements that add all the fluid energy; the process elements that make the product or provide the service; and the control elements that improve the product quality. Figure 1 shows the piping system details. In this example system, the pump is an end suction design with a manufacturer's identifier of 10x8-17, operating at 1,770 revolutions per minute (rpm). The pump curve used in this example can be found in Figure 2. Based on the manufacturer's information, the pump suction flange is 10 inches in diameter, and the pump discharge flange is 8 inches in diameter, with the 17 indicating the pump's maximum impeller diameter.
Figure 1. Layout of the example piping system showing the pump and process elements. Control of the system is achieved by turning the pump off when not required. (Graphics courtesy of the author)
Figure 2. Manufacturer's supplied pump curve for the pump used in the example system Counting the Cost
First, we will look at the system with an 8-inch nominal size discharge pipe. This is the same diameter as the discharge flange on our pump. The resulting flow rate through the system is 1,438 gallons per minute (gpm), resulting in a head loss of 105 feet of fluid in the discharge pipeline. Adding the head loss of the pipeline to the system's static head of 200 feet results in a head of 305 feet for the process and control. The pump curve shows that a flow rate of 1,438 gpm through the pump results in a head of 305 feet. The balanced flow rate through the system is such that the head produced by the pump is equal to the head consumed by the process and control elements. Next, we will calculate the power cost needed to pump 1,000 gallons of water at 60 F through the 8-inch pipeline using Equation 1.
Pipeline Sizing Parameters
Rather than performing a detailed cost optimization for sizing pipelines, companies have developed piping specifications based on the process fluid being handled. These specifications have been developed over time based on the company's needs and experiences. A chemical process plant, for example, will typically have many pipe specifications for the various process fluids they handle, while an industrial plant may have a few specifications for the cooling fluids and transporting fluids needed for the process. The Crane Technical Paper 410, Flow of Fluids through Valves, Fittings and Pipe, provides recommended fluid velocities for general service applications, pump suctions and municipal applications. The pipe fluid velocity range for general service applications is between 4 and 10 feet per second. As demonstrated in Table 1, the 8-inch diameter pipe is on the high side of the recommended velocity range.How Pump Manufacturers Arrive at a Flange Diameter
Some end users may ask why the pump manufacturer does not size the pump discharge flange for the recommended pipe diameter. There are a variety of reasons for this, including the following:- The larger the discharge flange, the greater the pump footprint. Because one of the major costs of the pump is the pump case, a larger flange size would increase the size and cost of the pump.
- The distance the fluid travels from the impeller tips to the discharge flange is short compared with the discharge piping. As a result, higher fluid velocities within the pump can be used because of the limited head loss due to the moving fluid and the stationary pump.
- To minimize the number of castings required to meet its customers' pumping needs, a manufacturer may trim the impeller or design the pump to operate at various synchronous speeds. For example, the manufacturer supplying the pump in the example system makes it available with impellers ranging from 12 to 17.125 inches. In addition, the pump is available with both 1,200- and 1,800-rpm drives. The variation in the pump impeller diameter and synchronous speed affects the flow rate through the pump.
