Industry Insights
07/15/2016
In most pulp and paper applications, energy and unscheduled maintenance are two of the largest components of ownership cost. For this reason, improving pump efficiency is key to pump system optimization. Although certain mechanical and control modifications can improve reliability, selecting the best hydraulic fit is an often overlooked approach to system optimization. Energy and reliability are two sides of the same coin: A good rule of thumb is that where there is excess energy beyond what is required to move fluid through the pipes, there will also be unreliability. Three primary factors affect pump system reliability:
- operating speed
- operating point (percent of best efficiency point [BEP])
- impeller diameter
- efficiency of the pump as well as other system components
- overall system design (sizing and balancing measures)
- effectiveness of piping systems (e.g. reduced frictional pressure losses, matching of pump and system characteristic)
- efficient pump control (e.g. variable hydraulics, on-off control, etc.)
- efficiency of drives (motor and VSD)
- appropriate maintenance cycles
- Throttled valve-controlled systems. Often the valve is sized so that it operates less than 50 percent open, resulting in significantly higher energy costs. Also, the pump is forced to run back on the curve, away from the BEP.
- Bypass (recirculation) line normally open. Use discrete control logic to open and close bypass based on flow or pressure demand. Minimizing bypass flow rates lowers pump system speed and, subsequently, energy costs.
- Multiple parallel pump system with same number of pumps always operating. Implement multi-pump sequencing (two to four pumps) to meet flow and pressure demand. Turning off one or more pumps in low-flow demand periods provides energy as well as maintenance cost savings. Tighter pressure and flow control improves overall process reliability by reducing pipe vibration and collateral damage to instruments, valves and pipes.
- Constant pump operation in a batch environment or frequent cycle batch operation in a continuous process. Variable speed control logic can help prevent deadheading the pump against a closed discharge valve.
- Presence of cavitation noise (at pump, valve or piping). Intelligent variable frequency drive control offers dry-running and cavitation protection. Intelligent pump control offers vibration monitoring with alarming.
See more Industry Insights by Mike Pemberton here.
