Q. When dealing with wastewater treatment pumps, what concerns pertaining to site conditions are relevant? A. The type of pump that can be used depends on the location of installation. These location considerations include the size of the installation space, discharge piping alignments, wet-well depth, interior/exterior installation and power. The area where the pump is installed must allow space for proper mounting of the pump and driver assembly, for the inlet and discharge piping and valves, and for the necessary power wiring and switches. Operators and maintenance personnel must have enough space to access the pump and complete any required work or removal of the pump. Because their installation space is significantly different than that of other pumps, horizontal and vertical pump assemblies require special evaluation. New designs allow designers to create the space required to meet the new pump requirements. Retrofit designs may not afford this ability. The existing structure, wet well, hydraulics, control sequencing or installation requirements may become the primary considerations when end users are choosing a pump. The fluid being pumped can create specific requirements for the driver and/or the power distribution components that serve the pump assembly. These requirements can change the sizing of the components, so users should also evaluate these factors when installing the pump assembly. For more information on wastewater treatment pumps, see HI's newest guidebook Wastewater Treatment Plant Pumps: Guideline for Selection, Application, and Operation. Q. What types of pumps are recommended for the primary treatment stage in a wastewater facility?
- Regulate the operation of pumps or the station in relation to wet-well depth, discharge flow or force main pressure, which can potentially eliminate the need for control valves
- Provide energy-efficient operation of pumps by matching best efficiency operating points and/or matching pump operation to varying demand loads
- Ability to over-speed pumps to meet certain specific short-term application conditions
- Provide power phase conversion (producing three-phase power from a single-phase power supply)
- Create power at a different frequency (e.g., producing 60-Hertz [Hz] power when only 50 Hz is available)
- Adjust the pump operational speed (or torque) instead of using a control valve to restrict pump output, which reduces downstream flow or pressure
- Reduce mechanical stress of conditions such as cavitation and water hammer on both the pump and pump system
