In Texas, the hot, dry summers make water use and conservation a top priority. TPC San Antonio, a resort featuring two golf courses, sought a way to keep the grass green without harming the local ecosystem. Course management turned to an advanced irrigation system that focused on water recovery, reuse and environmental safety. Before the resort was built, ecologists opposed the project out of concern that fertilizers in runoff would harm the Edwards Aquifer. They also worried that construction would displace local wildlife and disrupt habitats, including the 750-acre bird sanctuary bordering the resort grounds. Balancing water use requirements with these environmental concerns required an advanced irrigation system with a specialized monitoring solution. In dry regions, advanced irrigation systems keep areas like golf courses lush and green. TPC San Antonio’s two golf courses—18 holes spanning 7,000 yards—employ a closed-loop irrigation system. This system traps runoff and drainage and redistributes it to one of 14 capture ponds. The capture ponds are then tapped for irrigation on a strict schedule that allows TPC San Antonio to maintain its golf courses while prioritizing water conservation.
