As major independent and national oil companies in the Middle East and North Africa face the possibility of fewer projects and tighter budgets, producers can enhance efficiency by modernizing aging equipment. Metering pump technology plays an important role in operational efficiency and saves costs by increasing safety, improving production and maximizing well life. In Egypt, energy demands have more than doubled during the last decade. With a growing economy and a rising standard of living, consumption is rising faster than production. Egypt has traditionally relied on a combination of natural gas and crude oil to meet domestic demand. While oil production has remained steady, gas production has increased. The market for unconventional shale and sandstone products is expected to be a significant growth area in the region.
Increased Well Life
Metering pumps keep oil and gas flowing by injecting chemicals such as methanol, monoethylene glycol and corrosion inhibitors into main lines to prevent hydrate formation, wax and scale deposits, and corrosion. These deposits hinder flow and lower product recovery rates. If the flow of these chemicals stops, production can come to a halt. Corrosion inhibitors also add a higher level of safety to operations, by helping to prevent leaks and spills at the wellhead, and in pipelines that carry the oil and derivative petroleum products from upstream wellheads to downstream refineries. For more than 20 years, this Egyptian operator had been extracting oil and gas consistently. Locally built chemical injection skids with high-pressure pumps injected corrosion inhibitors into wellheads to protect pipelines and increase pipe life. Methanol, glycol, demulsifiers and scale inhibitors prevented problems in production and the refining process. The operator's metering pumps had been constructed with a low-grade stainless steel. They required replacement parts and arduous maintenance that slowed operations. In addition to production delays, the pumps failed to deliver the chemicals as needed, risking clogs in the well. The Egyptian operator recognized the value in upgrading their metering pump technology. As a result, the new pumps are able to withstand the harsh environmental conditions and meet performance requirements while reducing the maintenance of existing pumps.Equipment Upgrades
All metering pumps should use durable materials and benefit from state-of-the-art design processes, delivering the right pump for the application.1. Liquid End
The most important part of a metering pump is the liquid end—the section of the pump that comes in contact with the acids, bases, corrosive liquids and slurries. Metering pumps must provide chemical resistance to the solvents and harsh materials that are pumped through them. The pump's motor drives a piston to create a vacuum through which chemicals enter the liquid end. Alternating piston strokes create pressure that closes the inlet value, opens the outlet valve, forces the liquids into an umbilical and then delivers them to the wellhead. The operator determines the precise dosage rates and implements them through a distributed control system.
