A well-known technique for increasing pump reliability is sealing the bearing housing with non-contacting bearing isolators rather than contact seals. Because contact seals use contact as their sealing method, they have a more limited life expectancy, since they can wear at the point of contact or groove the shaft. When this occurs, lubricant will escape to atmosphere and contaminants will enter the bearing housing, leading to bearing failure. Though more expensive, bearing isolators effectively retain lubricants and exclude contaminants while providing a virtually infinite life expectancy. This increases mean time between repair (MTBR). The most common perception of bearing housing seal failure on process pumps is lubricating oil leaking from the bearing housing. For most operators, the analysis is simple: no leaking oil means the seal is fine while leaking oil equates to failure. Though true for contact seals, the presence of leaking oil from a bearing isolator is most likely due to factors other than seal failure. Following are some of the more common causes of bearing isolator lubricant leakage in process pumps.
