When the West Side sewage pump station in Onondaga County, New York, prepared to undergo its first major upgrade in more than 30 years, the project required a bypass system to move a peak flow of 30 million gallons per day (mgd). The West Side pump station is the second largest pump station in Onondaga County, taking in about 8 mgd of sewage from communities in the western suburbs and then pumping it to a nearby wastewater treatment plant. The expansion and upgrades would add more sewer capacity to reduce sewage overflows into Lake Onondaga during heavy rains, and expand its capacity and increase efficiency. The county’s Water Environment Protection Department hired local contractor C.O. Falter Construction to oversee the bypass project. The initial design called for using the station’s existing pumps during the expansion and upgrades. But it was later determined that the pump station’s existing pumps would only bear 19 mgd of water, missing the target by 25 percent. It became apparent the job would require a temporary bypass system to meet the maximum flow capacity. The contractor and pump supplier set out to design and install a temporary system to convey the full amount of flow within the same footprint as the original pumps. This helped the project avoid road closures and traffic delays. Additionally, the pump station is in a highly visible, noise-sensitive area, so loud diesel equipment was not a practical solution.
Temporary system offers long-term solution with off-site condition monitoring capabilities.
Xylem
04/12/2019
