A Kansas treatment plant expanded operations to meet federal requirements for effluent nitrogen and phosphorus levels.
09/02/2014
Several years ago, the Environmental Protection Agency (EPA) began an initiative to control excessive nitrogen and phosphorus pollution entering the Gulf of Mexico through watersheds. Although phosphorus and nitrogen are nutrients needed for aquatic plant and algal growth, excess amounts can have damaging effects. Farming states were under pressure to restore their surface water quality.
Too Much Nitrogen & Phosphorus
Surface water affected by excess nutrients turns green from algal blooms through a process called eutrophication. The anaerobic conditions produce an unpleasant odor and deplete aquatic life. Pesticides from the country’s booming agriculture industry had introduced excess nutrients to lakes, rivers and groundwater resources at the time of the EPA’s initiative. Kansas, one of the highest wheat, grain and beef producing U.S. states, has 244 streams and 187 reservoirs with nutrient-related impairments. Based on Kansas Department of Health and Environment (KDHE) data, point sources such as municipal wastewater treatment plants account for 18 percent of total nitrogen and 25 percent of total phosphorus loading in the state. The city of Olathe, along with many other cities in Kansas, upgraded its water treatment facilities to decrease these nutrient levels. Built in Olathe in 1984, the Cedar Creek Wastewater Treatment Plant had already undergone several expansions to meet increasing water demand from residents. Designed for a 2.5 million gallons per day (MGD) capacity, the original plant had a headworks building with bar screening and grit removal, two oxidation basins equipped with mechanical aerators and two 50-foot final clarifiers. In 1997, the capacity was increased to 3.0 MGD with the addition of a final clarifier and ultraviolet disinfection. The plant added a centrifuge dewatering system and aerated sludge holding basins in 2005. In 2008, the facility was expanded again to include an effluent pumping station. However, average flows of 3.75 MGD hydraulically overloaded the upgraded plant. A new round of upgrades lowered the effluent nutrient levels and further increased the plant’s hydraulic capacity to 5.25 MGD.Lower Nutrient Levels
In June 2010, Olathe broke ground on the Cedar Creek Wastewater Treatment Plant expansion. The expansion would increase the plant’s capacity by 1.5 MGD for a total capacity of 5.25 MGD. The capacity would reduce the frequency of wet-weather discharge overflow and provide biological nutrient removal (BNR) to lower effluent nitrogen and phosphorous concentrations. The structural upgrades included two parallel trains, including the new BNR treatment process.BNR Treatment
The BNR plant design incorporated an aeration system and submersible mixers that introduce dissolved oxygen into the wastewater (see Image 1). The small bubbles from the aeration system have a larger surface area and longer residence time in the treated water than larger bubbles would.
