Key insights into lowering system pressure will increase efficiency.
Singer Valve
05/12/2017
If pressure feeding into a zone needs to be lowered, the traditional method employed is to install a pressure reducing valve. This is a valve that will limit the outlet pressure of a valve to a preset pressure regardless of the flow rate and the inlet pressure. The location of this valve needs to be in an accessible area—typically in a valve vault, as it will require occasional maintenance.
