Identifying inefficient units is one thing, but fixing them can be time consuming, frustrating and expensive.
Hydraulic Institute
07/19/2017
The terms net positive suction head (NPSH), preferred operating region (POR) and allowable operating region (AOR) are common in the pumping industry, but many pump users do not fully understand the concepts or their impact on pump reliability. This article is aimed at defining the terms so that pump users understand their meanings. Users can also learn about resources available to better understand the requirements and why it is important to operate a pump within its POR and with adequate NPSH margin.
Industry Standards
To address these two important issues of required NPSH margin and operating regions, the Hydraulic Institute published and recently revised two American National Standards covering the topics, providing recommendations on the NPSH margin required for pumps by market used design and the POR for pumps of different designs.- ANSI/HI 9.6.1-2017 Rotodynamic Pumps – Guideline for NPSH Margin
- ANSI/HI 9.6.3- 2017 Rotodynamic Pumps – Guideline for Operating Regions
Pressure & NPSH Terminology
To understand these points, the terminology used to describe energy in a system is critical. In the rotodynamic pump industry, energy is described by total head in meters (m) or feet (ft) added to a system. There is a direct relationship between head and pressure. If we focus on U.S. customary units, 1 pound per square inch (psi) is equivalent to 2.31 feet of water at 68 F (specific gravity = 1.0). To adjust for other liquids or water at a different temperature, specific gravity is used and 1 psi is equal to 2.31/(specific gravity) (feet).
Operating Regions
Pump impellers are designed to operate at a specific flow rate where there is a zero incidence angle between the inlet impeller vanes and the approaching liquid at a particular rate of flow, called shockless entry flow. The flow of shockless entry is typically near the pumps best efficiency point (BEP), and BEP is used as a proxy because it is more easily determined by people who did not design the impeller. Higher or lower rates of flow relative to the BEP cause a mismatch between the angle of the approaching liquid and the impeller vane inlet tips. The greater the incidence angle, the greater the potential for flow separation and cavitation to occur. Design characteristics for both performance and service life are optimized near the BEP, and the pump operates with maximum hydraulic efficiency. Therefore, operating as close to BEP as possible will result in maximum pump reliability. The Hydraulic Institute defines two important pump regions of operation. The preferred operating region (POR) is the range of rates of flow to on either side of BEP within which the hydraulic efficiency and operational reliability of the pump are not substantially degraded. The allowable operating region (AOR) is a wider range of flow, outside the POR, over which the service life of a pump is acceptable. When pumps are operated outside their POR, the flow through the pump is no longer uniform. This results in areas of flow recirculation and separation that can cause additional loading, flow induced vibration and local areas of cavitation, all of which result in reduced reliability. The AOR is impacted by factors such as hydraulic loads, temperature rise, vibration, noise, power limits, liquid velocity, pump and potential for clogging, NPSH margin, head flow curve shape, suction recirculation, and pump size. The user should consult with the pump manufacturer to determine this value.
NPSH Margin & Operating Region
To understand the NPSH margin required, it is important to understand the NPSH requirements (NPSHR) of the pump. NPSHR is defined as a minimum NPSHA, provided by the manufacturer, which is required of a pump to achieve a specified performance at a specified rate of flow, speed and pumped liquid. This definition requires engineering judgement and is not easily documented. Therefore, as early as 1932, the Hydraulic Institute implemented a 3 percent reduction in head at a constant flow rate caused by a reduced suction head as the NPSHR of the pump. This is because this value was the smallest head drop that could be consistently and practically measured (see Figure 2). Historically, and still today, manufacturers’ pump curves show plots of NPSH3 and pump flow rate.
