Don't forget to take vapor pressure into consideration.
Summit Pump, Inc.
09/11/2018
This is the third article in a five-part series. Read the first part of the series here and the second part of the series here.
In the first part of this five-part series, we defined net positive suction head available (NPSHa) and walked through a simple calculation based on ambient temperature water for a flooded suction condition. In part two, we worked through an almost identical situation except the water source was at a level below the pump centerline, which is a suction lift situation. In both cases, the systems were open to atmospheric pressure, located at the elevation of sea level. The liquid temperature was at ambient 68 F.
Flooded Suction Pumping Hot Water
In this third part of the series, we will investigate what happens when the liquid temperature is above ambient. Before we get to the formula and the calculation, I recommend a review of the definition for vapor pressure. I covered vapor pressure in my April 2018 Pumps & Systems column should you wish to revisit. A brief summary is as follows. A liquid in an open container will eventually evaporate to a vapor unless some other force is present to prevent the change from occurring. In most examples, that force is simply atmospheric pressure. Even a bowl of water left on the kitchen counter will evaporate away over time, but it will happen at a significantly faster rate with each incremental increase in temperature. The amount of energy associated with the vapor pressure is subtracted from the total energy level available for the NPSHa. The energy associated with the vapor pressure is always a negative quantity. In the context of NPSHa, vapor pressure is not a friend to the pump. For a given temperature, a liquid exerts a certain pressure to the atmosphere, and the atmosphere exerts a counter pressure in return. For water temperatures below 212 F, the atmospheric pressure is greater than the vapor pressure. Those two pressures (vapor and atmospheric) would be in equilibrium if the water was at 212 F at sea level, where the water would begin to boil. If the pump example was at higher elevations (lower ambient pressure and consequently a lower equilibrium temperature) the water would boil at a lower temperature. Vapor pressures for water at various temperatures are easy to calculate or obtain in a reference source, but it is often very difficult to find reliable information on vapor pressures for other liquids. It is not uncommon for the end user/operator to be using the incorrect vapor pressure in their calculations.The Formula for NPSHa
Remember that we are calculating NPSHa, so we do not need to include velocity head. Velocity head would be included if we were measuring NPSHa. Please refer to Image 1.
