Four main technologies are available, and plant operators can optimize operations by selecting the best combination of these options.
Neptune Chemical Pump Company
10/17/2016
- Sodium hypochlorite: Widely known as bleach, this liquid is most commonly used for disinfection at the treatment plant. This chemical is one of the most difficult to handle because it corrodes most metals it comes in contact with, and it cannot be mixed or stored with ammonia or other acids, organics and reducing agents used at the plant. It is also difficult because of its tendency to off-gas, which can cause metering pumps to become gas-bound. To prevent this, special vent valves are available for diaphragm pumps. Peristaltic pumps, which do not allow this phenomenon to occur, also can be used. Sulfuric acid: Used for pH adjustment, this chemical is provided either as a concentrate or dilute. Concentrated solutions can be handled in many situations with cast iron, steel materials or Alloy 20, while dilute solutions require plastics such as PVC or Kynar.
- Sodium hydroxide: Also used for pH adjustment, this chemical is often provided in solution strengths from 25 to 50 percent. Metering pump elastomers, such as Viton (a material often used for O-ring seals within a metering pump), are not compatible with sodium hydroxide, so they require special care. Especially in higher solution strengths, this chemical tends to gel in the pump if the pump is idle for a period of time. Flush valves or special pump heads can assist with this issue.
- Sodium bisulfite: This is one of the most commonly used dechlorinating agents at treatment plants. A mixer is usually required to keep this chemical in solution in the metering pump supply tank. Suitable materials for this chemical include plastics, such as PVC and Kynar, and metals, such as 316 stainless steel.
- Emulsion polymer: Fed as a coagulant to assist the dewatering equipment within a wastewater treatment facility, this chemical is shear-sensitive once hydrated and is often extremely viscous. Diaphragm pumps with high-viscosity head designs or peristaltic pumps are often required.
1. Mechanical Diaphragm Metering Pumps
Mechanically actuated diaphragm metering pumps are easy to implement and operate, which makes them an attractive alternative for many applications. They typically have a lower initial cost than other motor-driven metering pump designs, especially at higher flow rates, but they can have higher operating costs. Because the diaphragm is attached to the piston for a positive return usually aided by a spring, these pumps offer excellent suction-lift capabilities and can handle liquids that off-gas, such as sodium hypochlorite, and more viscous chemicals. These pumps are somewhat limited in discharge pressure capabilities, with many being around 100 to 150 pounds per square inch (psi) (7 to 10 bar) max. Repeatable accuracy is typically about +/-2 percent. They are generally not offered with an on-board relief valve, so an external relief valve is usually required to prevent damage to the pump in an over-pressurized situation.2. Hydraulic Diaphragm Metering Pumps
As a low-maintenance pump designed for 20 years of service, hydraulically actuated diaphragm metering pumps are ideal for operation in the harshest chemical-handling conditions. Their longevity and minimal maintenance requirements are possible because most of their moving parts are submerged in a bath of hydraulic fluid and because the diaphragm is hydraulically balanced..jpg)
3. Solenoid Diaphragm Metering Pumps
Solenoid-actuated, or electronic, metering pumps are an economical option in wastewater treatment operations for low-flow/low-pressure chemical-dosing applications. They are generally available to a maximum of 20 gallons per hour (gph) (76 liters per hour). At those capacities, maximum pressures are about 30 psi (2 bar).
4. Peristaltic Pumps
This pump technology, simplistic in its design, is well-suited for handling viscous and abrasive chemicals. Because the design features a rotor with shoes or rollers that squeeze the hose or tube and force the liquid to the discharge port, peristaltic pumps are able to run dry—a feature that technologies like some progressive cavity pumps cannot provide because their rotors and stators may be damaged in dry-run conditions. Peristaltic pumps also do not have valves that can become clogged. This is an important consideration when the pump needs to be shut down during a product run. The lack of valves in a peristaltic pump eliminates any clogging issues, especially when handling viscous liquids or those that will solidify or become gelatinous when resting. This also makes the peristaltic pump ideal for handling abrasive or corrosive chemicals.Help from Manufacturers
While these pump technologies can provide a list of benefits for wastewater treatment plant operators, the challenge is knowing which pump is best for which chemical-metering application. This is where the pump manufacturer can lend a hand.
Optimizing Operation
Ensuring that communities have the cleanest water possible places a great amount of pressure on water and wastewater treatment facilities to perform their jobs as effectively, efficiently and safely as possible. The various chemicals that may be required in the different treatment processes only increase the plant operator’s risk. An operation will reach the pinnacle of proper performance only if the best pump technologies are chosen for each of the many critical chemical-metering processes.
