The balance between cost and ease of installation should be the major deciding factor.
08/03/2015
Mechanical seals consist of a rotating element and a stationary element, each with a lapped, precision-smooth mating face (see Figure 1). Seal performance is determined primarily by the condition of the faces and the pressure applied to them. Other key factors are vibration, heat and pumpage characteristics. Depending on the application and user's needs, different seal types may be appropriate.
Component Mechanical Seals
Standard mechanical seals are typically component seals. When users order a replacement, they typically receive a box containing seal faces, holding brackets, O-rings, boots and other parts that require the skills of an experienced pump technician to install and adjust properly (see Image 1).
Cartridge Mechanical Seals
Cartridge mechanical seals and component seals use similar components, but the stationary components of cartridge seals are preassembled in a housing, and the rotating components are preassembled on a shaft-mounted sleeve that is sealed with an O-ring. The cartridge seal housing typically replaces the gland cover plate and seals to the pump housing with a gasket, an O-ring or other elastomer. Since cartridge mechanical seal components are preassembled onto the sleeve and into the cartridge housing, errors in parts installation are unlikely. The amount of spring tension applied to the seal faces is an important factor that affects successful seal installation. On component seals, technicians can set this tension manually by adjusting the length of the installed seal spring. With cartridge mechanical seals, the spring tension is preset. To ensure the proper tension, a retaining device holds the rotating and stationary elements in alignment until after the seal is mounted. While the details of whether a cartridge mechanical seal can be fitted to an application are complex, one criterion is whether the seal installs from the wet side or dry side of the seal chamber. Pumps with a seal that installs from the wet side, behind the impeller, are generally not candidates for cartridge mechanical seals. In addition, submersible pumps, which are usually fitted with dual component seals, cannot be converted to cartridge mechanical seals because the seals install from the wet side of the pump.Component vs. Cartridge
For end users deciding between a component and cartridge seal, the primary considerations are cost and ease of installation. If a competent pump technician services the pump during overhaul under good working conditions, ease of installation may seem like a minor issue. However, the concern will be for subsequent seal replacement during an emergency outage. Cartridge mechanical seals may cost two to three times component seals, so unless otherwise stated, competitive repair bids are typically for component seals. Despite the higher initial investment, however, a cartridge seal can be a more cost-effective, long-term solution, given the expectation that pump maintenance may require in-service seal replacement. Potential savings accrue from lower labor costs and less production downtime when subsequent seal replacement is needed. Projected savings also include the elimination of seal failures resulting from improper installation of component seals.Dual Seals
Dual seals are effective solutions for many pumping environments and applications that are tough on seals, including high temperatures, high pressures and foul pumpage laden with abrasives. Dual seals have a chamber between the seals into which barrier fluid can be pumped to provide cooling, lubrication and protection from abrasives in the pumpage. While redesigning a single-seal pump to accept dual component seals would be challenging, the precision components of a cartridge mechanical seal can be designed as a dual seal that can easily fit in the same space as a single component seal (see Image 2).
