A new era in how propane would be transported, supplied and distributed in Minnesota dawned in May 2012. That's when Kinder Morgan Energy Partners, L.P., announced the launch of its Cochin Reversal Project, which would see the reconfiguration of its Cochin pipeline from one that supplied propane to the U.S. and eastern Canada to one that would ship diluents (light condensates/C5/Pentane) from Kankakee County, Illinois, to the oil sands region of Alberta, Canada. First placed in service in 1978, the 12-inch, 95,000-barrels-per-day Cochin pipeline was used to transport propane and other light hydrocarbon liquids 1,900 miles from Fort Saskatchewan, Alberta, to Windsor, Ontario, with intermediate distribution points located in seven U.S. states: North Dakota, Minnesota, Iowa, Illinois, Indiana, Ohio and Michigan. Over the years, the Cochin had become the largest single source of propane supply in Minnesota, with 38 percent of the state's annual propane supply delivered through the pipeline. "We use between 400 and 500 million gallons of propane in Minnesota annually. Approximately half of that is used for residential home heat, 40 percent is used for agriculture, and the remaining 10 percent is a mix of commercial, industrial and motor-fuel applications," said Scott McClelland, engineer at LPG & NH3 Supply Inc., a supplier of equipment and services for use in the propane market in Minnesota. "When they shut down the Cochin pipeline, it was imperative to find new ways to get propane into the state to keep up with demand."
Filling The Void
Alliance Energy Services—through its subsidiary Alliance Midstream LLC in Benson, Minnesota, which owns, operates, acquires and develops midstream assets used in the transportation and storage of energy products—knew that creative thinking would be required to replicate the delivery volumes of propane that would be lost.
Lending A Hand
An important piece of equipment in the propane-railcar unloading process is the compressors that are used to remove the propane from the tankers and transfer it into the storage tanks. "We've got four compressors total, which are good for unloading two railcars at a time," McClelland said. "What they're doing is hooking up the railcars, using the compressors to unload the liquid and perform vapor recovery. The terminal runs all the time, and with those compressors they can turn their 1.5 million gallons of storage, fill it and pump it out, all in 24 hours. They can offload 16 cars in only six or seven hours.".jpg)
