Electric Submersible Pump Technology
Most producing oil fields utilize an electrically driven downhole pumping system to bring oil to the surface. The pump typically comprises several staged centrifugal pump sections that can be specifically configured to suit the production and wellbore characteristics of a given application.
ESP systems are a common artificial-lift method, providing flexibility over a range of sizes and output flow capacities. ESPs are typically used in older reservoirs on wells with high water cuts (percentage of water to oil).
ESPs provide cost effective production by boosting fluid production from these less efficient, older reservoirs. ESP completions are an alternative means of obtaining artificial lift in wells having low bottom hole pressures. ESP completions are the most efficient choice for high volume capable wells. Production rates up to 90,000 barrels (14,500-m3) of fluid per day have been obtained using large ESPs.
ESP Components
The ESP system consists of a number of components that turn a staged series of centrifugal pumps to increase the pressure of the well fluid and push it to the surface. The energy to turn the pump comes from a high-voltage (3-kV to 5-kV) alternating-current source to drive a special motor that can work at high temperatures of up to 300-deg F (150-deg C) and high pressures of up to 5,000-lb/in² (34-MPa), from deep wells of up to 12,000-ft (3.7-km) deep with high energy requirements of up to about 1,000-hp (750-kW).
The ESP uses a centrifugal pump (see Figure 2) which is attached to an electric motor and operates while submersed in the well fluid. The sealed electric motor spins a series of impellers. Each impeller in the series forces fluid through a diffuser into the eye of the one above it.
In a typical 4-in submersible pump, each impeller will add an approximately 9-psi (60-KPa) of pressure. For example, a typical 10-stage pump will develop a pressure of about 90-psi (600-KPa) at its outlet (i.e. 10 impellers x 9-psi). The lift and capacity of the pump is related to impeller diameter and the width of the impeller vanes. The pump pressure is a function of the number of impellers.
For example, a ½-hp 7-stage pump may deliver a high volume of water at a low pressure while a ½-hp 14-stage pump will deliver a lower volume, but at a greater pressure. Like all other centrifugal pumps, an increase in well depth or discharge pressure will reduce the capacity.
As one of the higher volume methods of lift, ESPs offer advantages over some other high volume methods because they can create a higher drawdown on the formation and achieve more production. However, they also present problems that must be solved, such as gas interference and sand production.
More than 60 percent of producing oil wells require some type of assisted lift technology to produce the recoverable oil originally in place. About 14 percent of some 832,000 wells lifted worldwide are/were lifted with electrical submersible pumps (ESP) (from World Oil, 2000).
Artificial lift systems are an essential part of production, especially in maturing oil fields where the reserves lack sufficient pressure to easily bring the crude oil to the surface. As the production of natural gas and crude oil continues to diminish and water production increases (particularly in water-driven reservoirs), the lease operator may begin waterflood, an enhanced recovery method in which water is injected into the reservoir at one well to drive hydrocarbons to other wells.
Given time, however, oil production will continue to fall and water production will increase. As this occurs, the pumping time for a given beam pump system, for example, increases until the lease pumper is producing the well 24 hours a day. At this time, the most practical way to improve production is to install a system with greater production capability.
Where heavy crudes (up to a point), limited access to injection gas, higher water cut or low bottomhole pressures preclude the gas lift option, an ESP can be used. ESPs generate centrifugal force to pressurize wellbore fluids and are capable of lifting fluids from depths of 20,000-ft (6,100-m) or more (Shepler et al., 2004). However, installations to 10,000-ft and less are more common.
ESPs are dynamic pumps that use multiple stages to raise the liquid pressure high enough to overcome static head of the discharge column. These pumps were traditionally installed in high-volume artificial-lift applications that are seldom appropriate for deliquifying gas wells (Simpson, 2006).
However, new work from Centrilift shows using ESPs down to 40-bpd to 100-bpd at depth to lift liquids off gas wells. The motor is shrouded, or recirculated, or just constructed with high temperature trim. It remains to be seen if this will be a trend. The pumps used were higher volume stages run to the left of the curve.
ESP systems may be the best choice for larger oil wells that have declined and desire to increase production, such as the case in many Middle East countries. Older gaslift systems with now high water cut would produce to lower pressure and produce higher recoverable oil if money were spent to reequip them with ESPs. See Figure 1 for an idea of range of operation.
ESPs offer the highest yield of most deep-well artificial lift systems, but suffer the highest frequency of expense and repair. ESP systems also offer superior performance in somewhat gaseous and water-infused environments.
Gas and water occur naturally in high percentages with crude oil. The gas and water must be separated from the flow of crude oil in order to pump it to the surface. High percentages can cause gas locking in the pump mechanism, resulting in a serious decrease in flow delivery - requiring the entire production string to be pulled from the well and re-primed.
Pumps & Systems, February 2008
