Construction projects on the scale of Stuttgart 21 in Europe require careful planning combined with expertise in a number of engineering fields.
Sulzer Pumps Inc.
02/21/2017
Large civil engineering and construction projects are often complex, but a job can be even more challenging when it involves digging 19 miles (30 kilometers [km]) of tunnels and installing high-speed rail lines. The concept of this project, known as Stuttgart 21, was to replace the existing railway terminal station with a high-capacity underground through-station that would join plans for a high-speed link to other European cities. The main construction work on Stuttgart 21 began in 2010 and is expected to continue beyond 2023. The finished project will join the 1,500-km “Magistrale for Europe” high-speed line connecting Paris, Strasbourg, Stuttgart, Ulm, Munich, Vienna, Bratislava and Budapest.
Simultaneous Construction
As the project has developed, nine tunneling sites have become operational, all working around-the-clock to create the underground links for the railway. To date, these sites have required more than 200 pumps to keep the water away from the engineers until the tunnel lining process has been completed. The pumps vary in size from 2.0 to 56.0 kilowatts (kW), depending on the situation. The majority represent one company’s specific range that offers high energy efficiency as well as onboard level detection and data storage functions. The modular construction of the pumps simplifies maintenance and minimizes repair time, which lengthens the pumps’ operational time. The provision of support for the pumps was a critical factor for the consortiums responsible for constructing the tunnels. A pump company involved demonstrated that it could deliver a wide range of pumps that had the capacity, reliability and efficiency required for the project.
