Many industrial professionals think braided packing is an inferior and outdated fluid sealing technology. But braided packing a good choice for many applications. With proper product selection, reliable performance can typically be assured. However, a thorough equipment inspection before installation is critical. The components described in this article should be reviewed and documented on every work order and corrected before any repacking of the pump to achieve maximum performance. The shaft or sleeve is one component that everyone checks for wear, but they may not understand how to inspect it correctly. For an effective inspection, first examine the shaft and see where the predominant wear has occurred. Is it in front of the lantern ring or on the gland side? Front-side wear in slurries is most likely caused by a loss of flush water, often because the lantern rings or flush water lines are plugged. The wear could occur if personnel who add the packing rings do not completely repack the stuffing box.
