In last month’s column, we discussed how to use a piping system model for operator training, system troubleshooting and improvements. This month, we will discuss one of the fundamental engineering principles used to build a piping system model.
A core attribute of this type of model is the ability to determine the fluid energy anywhere in the system. If we think of it as an energy balance, we can see the interactions and contributions of each of the various components found in each circuit. If each piece of equipment and interconnecting piping is accurately described in the model, then the model will show how the total flow of fluid energy in and out of the system works under any expected flow rate or set of boundary conditions.
Every piping system consists of pump, process and control elements. Pump elements add all the fluid energy needed to operate the system. Process elements use the energy to move the fluid through the process steps or provide the desired service. Control elements use the remainder of the energy to maintain or improve the quality of the product or service. This concept is described in Equation 1.
