Lev Nelik responds to readers' questions about calculating and estimating pipe velocity
Pumping Machinery LLC
03/01/2019
I received good feedback from the readers on my January 2019 P&S article “Calculating vs. Estimating Pipe Velocity.” Below are some of the letters and my responses.
Reader 1
Dr. Nelik, I believe there may be an error in [the article]. The pump curve shown indicates a service condition of 70 gallons per minute (gpm) at approximately 103 feet total dynamic head (TDH), but your article cites the operating condition at 80 pounds per square inch gauge (psig) with a 5 psig suction pressure. This would be a pump head of approximately 75 psig, or 173 feet TDH, far above the displayed pump curve’s capability. Since the head axis is not labeled, and thinking you may have modified the head axis to reflect psig, I double-checked the brake horsepower (bhp), which checked at 3.31 bhp and, thus, verified the head in feet. As a fellow author, I appreciate when people call me on a mistake or a simple error, and I hope you accept this in the same spirit I intend. Edward Butts Salem, Oregon Dr. Nelik responds: Thank you, Ed, you are absolutely correct: I did use the wrong curve. It should be a 1.5 x 1-8 size pump, not the 1.5 x 1-6 the performance of each I showed as an example. Even though this does not change the calculations presented, your observation is very perceptive, and I appreciate you bringing it to my attention.Reader 2
In your January article, the difference that gauge elevation and velocity head contribute to differential pump head was evaluated for a specific example. There was a 9 percent error in the “on-the-fly’’ differential gauge-only head value when compared to the “long-way” calculation for this example. The question, “is this error (9 percent head difference) big and significant?” may depend on the application, actual gauge locations and pipe sizes, and what is done with a gauge-only differential pump head value. The closer the discharge and suction gauge elevations are to being equal, and the closer the discharge versus suction pipe size ratios are to unity, the smaller the error will be between a gauge-only differential head value and the “long-way” calculation. In the article example, if the differential gauge-only head value is taken to be the actual pump head and compared with the pump curve, it might be assumed that this pump was operating far to the right of its intended duty point. If acted on with subsequent system changes, unintended plant and pump consequences could occur. It may be best to treat a gauge-only differential pressure/head value as an approximation, not to be used for system changes. (Note, the Image 1 stage pump performance curve duty head value appears to be about 100 feet; the example of 188 feet required head value is beyond the range of this pump curve.)
Reader 3
Dr. Nelik, as you asked in your January article, here are my thoughts on gauge correction and velocity head corrections. My most extreme example of ignoring the gauge correction occurred years ago at a municipal water pumping station. The customer complained that the new pump was not producing enough pressure. I was sent 500 miles to determine what was wrong. The new pump was located on a lower basement floor and the control room was on the ground floor. For convenience, the pressure gauge was just outside the control room. Because this was before the dawn of the electronics age, the pressure was communicated from the pressure tap at the pump to the gauge via tubing. No one had considered that since the gauge was 30 feet above the pressure tap, a 30-foot “gauge correction” had to be added to the gauge reading. When done, the corrected pump pressure was as it should be. It was a nice, easy trip. Today, most pressure indicators involve a transducer at the pressure tap, and thus any gauge correction is the difference in elevation between the transducer and the pump centerline. In most cases, both the suction gauge (if there is one) and the discharge gauge are close in elevation. Thus the “gauge correction” is small and has little effect unless the pump TDH is low. Nevertheless, I always include it, just to be consistent. The velocity head correction is a bit more complicated. Since it involves the difference in velocity in the pipes between the location of the suction and discharge gauges, it can be significant. Most process pumps have relatively high velocities at the suction and discharge flanges, as in your example. If the pressure gauges are located on the flanges, then the velocity head correction can be significant for relatively low head pumps. For higher head pumps (i.e., over 200 feet TDH) it often is negligible. In many cases though, the gauges are not located on the pump flanges. Since most pumps have increasers (or reducers) near the flanges, the pressure gauges are located on larger pipes where the velocity heads are much smaller. In those cases the velocity head correction is negligible. In all cases it should be emphasized that the velocity heads must be calculated at the locations of the pressure gauges. So, to definitively answer your question of how much error is there if both are ignored—it depends! But since they are easy to calculate, don’t ignore them, and that way you are always consistent and do not miss anything. Barry Erickson Pump Improvement Engineer, Cummins-Wagner, Siewert Equipment Co. Dr Nelik responds: Thank you, Barry. Good insights and valuable advice! Water pumping stations may have various pump designs (either dry or submersible), and a typical arrangement often has three to four pumps. By not generating enough pressure by a pump, operators may be forced to start another pump in parallel, which reduces their stand-by availability margin and complicates operating logistics. So, your example is very relevant. Another example is perhaps another extreme—a pump at any gas station! A 10 percent error on a typical $40 tank-fill may mean $5. It may be only $5, but why from my pocket? A less critical example on the other end of the spectrum could perhaps be offloading from a storage tank to a service tank via occasional periodic process replenishment. If such pump-out is done at off-peak hours (perhaps overnight), the difference between a 30-minute fill-up and 33 minutes is insignificant. And so you are right, as we both said—it depends! To our readers, if you have any additional comments to supplement Barry’s view, let us know. I will also present your feedback at my upcoming Pump School session.
