This technology can help reduce blockages, detect damaged equipment and avoid dry runs, thus reducing motor stress.
Invertek Drives USA
06/05/2019
In the increasingly competitive domestic and international processing markets, businesses are constantly looking at ways to reduce costs and increase profitability. The pump systems industry is helping end users achieve this through the integration of technology, such as variable frequency drives (VFD). VFDs designed specifically for pump control can help achieve energy savings of at least 20 to 30 percent in most pump control applications. Combined with associated technology, some VFDs can ensure efficient control of multiple pumps as well as avoiding pump downtime by reducing blockages, detecting burst pipes and avoiding dry runs. Here are two case studies showing how VFDs helped save money and increase efficiency.
VFDs Keep Golf Course Green
One example is a Professional Golfers’ Association championship 18-hole golf course that had been using a single 150-horsepower (hp) pump and a 150-hp drive to control its underground irrigation system serving its 72-hectare (178 acre) course. The way the system was set up meant the entire course was irrigated even if greenkeepers wanted to target certain areas. If the existing pump or drive was out of service, the whole system would be inoperable, leaving the course without irrigation. The system was also inefficient, using water that was not needed. Four VFDs were introduced as part of the solution. The four VFDs are now used to control four 25-hp pumps that target zoned areas of the course. The VFD technology allows multiple pumps to work together to ensure optimized efficiency. The system is arranged so that one VFD is the master and the other three follow behind it. The master controls the other VFDs to maintain a constant system pressure within the pump system. The master VFD also ensures that if one or more drives is out of service, the remaining available drives can take control of the pumping requirements, ensuring continued irrigation for the course. The system can also detect low pressure, such as a leak in the system, blockages and dry-runs. This ensures that the motors are not placed under stress, reducing maintenance or replacement costs. The new targeted approach for the irrigation system means the golf club can cut water usage and reduce costs overall. The golf course noted savings that were an immediate return on investment.
