The addition of a grinder can maximize a pump station’s efficiency while curtailing overtime and unplanned maintenance costs.
JWC Environmental
02/23/2017
It is just past 10 on a Friday night when the phones of the on-call collection systems operators start ringing. It is an alarm for another pump clog at a sewage lift station—the second one in a week. If this situation sounds familiar, it might be time to retrofit a two-shafted grinder into some lift stations. Every municipality is a candidate for a grinder retrofit, and every municipality has a problem pump station network. There are several qualifiers that can flag a station as an ideal candidate for a retrofit: an older lift station not designed for higher-solids loading, outdated grinding equipment and, of course, recurring plugs in pumps that require manual cleaning.
Why Retrofit with a Grinder?
Many sewage lift stations in service were not designed to deal with the high-solids content found in today’s sewage. The heavy solids loading, often from disposable wipes, can easily overwhelm traditional pumps, including solids-handling pumps. Typically, when operators find their pumps clogging and failing, wipes-related clogging is the reason. Sewage composition has changed, so the industry standard of the 3-inch spherical solid that pumps were designed to pass no longer meets today’s needs. The addition of a grinder can maximize a pump station’s efficiency while curtailing overtime and unplanned maintenance costs. Grinding wipes and other waste before they reach the pumps is an effective method for preventing damage, eliminating risk, and reduce the time and energy costs associated with clogging. When the wipes are shredded into small enough pieces they do not reweave, rope together or form cumbersome rag balls in the lift stations, they remain in suspension and can be pumped easily.
