Approximately 75,000 gallons of water are required to produce 1 ton of steel. Water transfers heat, removes scale from steel and converts gases produced in ovens and furnaces. Nucor Corporation, the largest steel producer in the U.S., has a production capacity of more than 27 million tons of steel. The Nucor Steel Mill in Crawfordsville, Indiana, needed an innovative, cost-effective solution to monitor its water supply remotely for increased system control and visibility. A lagoon at the Crawfordsville plant provides the water for steel production. Five remote wells supply water to the lagoon using remote control. Plant personnel control well pumps, track well flow across the entire system and identify potential pipeline leaks. Widespread water system monitoring in steel processing extends well pump life and alerts operators of costly malfunctions.
Minimal Updates
For six years, Nucor used a private radio system to control the five well pumps. The Federal Communications Commission’s narrowbanding ruling, which went into effect in 2013, made the radio system obsolete. The ruling reduced communication channel bandwidth from 25 to 12.5 kilohertz. The frequency of the radios was outside the new bandwidth requirement.
