Cooling towers are used all over the world to cool processes in commercial and residential establishments. The towers can be found in hospitals and hotels, petrochemical refineries, power generation facilities, general manufacturing plants, and food and beverage production facilities. In each, these systems are responsible for cooling processes to keep production running smoothly and efficiently. The system works by circulating water through the process to absorb excess heat. The heated water then flows back to the cooling tower where it is reverted back to the ambient temperature through open air environments and evaporation. In order to continuously cool these processes, a significant amount of water is stored within the cooling tower and auxiliary system. If the location of the system is close to a cool water source, such as an ocean or river, it is possible to use a continuous source of fresh water. In most instances, continuous water sources are not available, and water must be cooled and reused multiple times.
Potential Problems
A few issues can arise when circulating and reusing large amounts of water. First, the hardness, or pH, of the water can cause fouling and scaling within the piping and valve system where the cooling system supplies water. This is often noticed in boiler systems where prevention of fouling is critical for optimal performance. To overcome fouling, most systems employ a chemical pump to dose anti-fouling and anti-corrosion agents into the water. The amount of anti-fouling agents and the size of the pump required to supply the chemicals are determined by the size of the system in place. The second issue is the growth of algae and microorganisms within the water system of open-air cooling towers. Algae and bacterial growth decrease efficiency, increase the cost of operation and potentially harm the people in the facility and surrounding neighborhood.
