Process control software reduces costs while increasing process accuracy and protection.
06/22/2015
Pumping systems account for a significant portion of a facility's energy use in many industries. In the majority of pumping systems, energy added to the working fluid by the pump is much greater than required by the process. System reliability and efficiency are major topics within the industrial sector, and they are key to achieving sustainable growth. Operating pumping systems reliably and efficiently requires optimum system control and protection.
![The number of applications in which induction motors are fed by VFDs is growing quickly. (Courtesy of WEG)](/sites/default/files/0615/WEG-1.jpg)
Automated System Control
The pump industry has successfully embraced the variable frequency drive (VFD), and the number of applications in which induction motors are fed by VFDs is growing quickly. Drive technology has stepped up to the plate to meet this growing demand and address—to some degree—the shrinking workforce.![Process control software is an effective solution for multiple pumps operating in parallel.](/sites/default/files/0615/WEG-2.jpg)
![Each motor is started or stopped based on runtime, extending equipment life.](/sites/default/files/0615/WEG-3.jpg)
- Reduce system component cost
- Improve system reliability
- Reduce maintenance costs
- Eliminate costly control panels
- Reduce system energy requirements
- Reduce overall installation costs
