LONDON (May 15, 2013) – Verder International received the 2012 European Air-Operated Diaphragm Pumps Product Differentiation Excellence Award from Frost & Sullivan at the Guoman Cumberland Hotel, London.
Frost & Sullivan Best Practices Awards recognize companies in a variety of regional and global markets for demonstrating outstanding achievement and superior performance. Verder was honored for showcasing growth, innovation and leadership. The Verderair Pure AODD pump was chosen by Frost & Sullivan's expert industry analysts after rigorous performance test against a selection of equivalent competitor products.
Analysts of Frost & Sullivan firmly believe Verderair Pure air-operated double diaphragm pump offers several superior benefits to end users such as the solid and robust design. The deviation from a conventional pump design results in increased efficiency, higher flow rate and reduced downtime.
The reliability of the pump is enhanced due to the incorporation of the double walled barrier chambers, which offer protection even when the diaphragm is ruptured.
The pump design is also praised for the ease of maintenance as the valves are accessible without the need to disassemble the pump during servicing. These benefits make Verderair Pure air-operated double diaphragm pump suitable for applications in solar, chemical processing and ceramic industries.
Verder International is a provider of fluid handling and pumping solutions with local distribution affiliates to support customers in their region. These local affiliates are providers of pumps and system solutions for chemical, water treatment, food and process industries.
