WASHINGTON (Oct. 25, 2013) – The Siemens Sitrans FM MAG 1100F (magnetic flow meter) has received the Food & Drug Administration’s Pasteurized Milk Ordinance (PMO) certification – necessary in the U.S. to sell into the milk and dairy market. The Sitrans FM MAG 1100F already has 3A sanitary certification and EHEDG approvals, and with the PMO certification, Siemens will now be able to sell through to OEMs, integrators and end-users in the milk and dairy segment. The Sitrans FM MAG 1100F sensor is specifically designed for the food and beverage and pharmaceutical industries, and is available with hygienic and flexible process connections. The product features compact or remote mounting, and easy “plug and play” field changeability of the transmitter. The flexibility of design allows for simple, on-site upgrades to IP68/NEMA 6P terminal box. The wafer design meets EN 1092, DIN and ANSI flange standards, and the sensor housing is made from corrosion resistant AISI 316 stainless steel. With a temperature rating of up to 200° C (392°F), the flow meter is well-suited for process industries. Siemens Industry Sector supplies products, solutions and services for industrial customers.
Fri, 10/25/2013 - 00:00
