According to the U.S. National Oceanic and Atmospheric Association (NOAA), the ocean holds 97 percent of the world's water while the remainder is found in rivers, lakes, underground pockets or glaciers, often in difficult locations to access. As a result, with global population growth, there is a pressing need to limit water use, streamline water treatment processes and increase the efficiency of desalination technology. Desalination is capital and energy intensive, but demand for the process has grown rapidly in the Middle East. A 2009 United Nations report titled "The Role of Desalination in Addressing Water Scarcity" states that desalination has been in use for 50 years and has become an indispensable process for ensuring that potable water is available across the region. Due to the continuous growth in capacity, the Middle East has almost half of the world's desalination capability, which supplies the majority of its freshwater demand, according to the UN report. The area's estimated average annual rainfall is 10.2 centimeters, which is about a tenth of the global average of 103.3 centimeters, according to climate experts. At the same time, the region has experienced a high rate of population growth, which has more than tripled in the last 34 years, according to the Al-Hayat Arabic daily. For these reasons and others, such as aging water treatment facilities, water resources are becoming increasingly scarce. Considering the cost of running pipelines and building desalination plants, it is important the pumping stations, booster stations and pipelines are designed and built to ensure maximum efficiency and reduced life-cycle costs. Energy and maintenance costs are typically the greatest expenses over a system's lifetime. While these systems have historically been designed with efficiency in mind, the use of pipe modeling software that identifies the optimum design and lowest life-cycle cost for pumps and piping is becoming more popular. These software packages ensure that all possible iterations of pump and pipe sizing are considered. There are thousands of iterations of pump and pipe dimensions that can work for a given design, but software models aimed at the lowest capital costs and minimum energy usage can identify the best combinations over the short and long term.
Designers can find short- and long-term savings by using a non-traditional approach.
11/21/2015
