Pumps & Systems, June 2008
While driving a car with the gas pedal to the floor and then controlling your speed using the brake is obviously inefficient, many facilities use the approach for pump control. Flow control with throt­tling or restrictive devices sacrifices energy efficiency and results in unnecessary costs. However, with an understanding of basic principles, an analysis of the specific application, information about available control solutions and evaluation of technologically advanced equipment, facilities can make a quantum leap in improving the efficiency and econ­omy of pumping operations.
The Basics
Energy efficiency starts with motor speed control. Sixty-five percent of all electrical energy used in the United States operates flow loads such as pumps, fans, blow­ers and compressors, mostly powered by constant speed induction motors. When output flow requirements fluctuate in such systems, an external means of adjustment is needed.
Commonly used methods for flow control include throttling or restrictive devices such as valves, outlet dampers, inlet vanes and dif­fusers. Mechanical speed changers and recirculating sys­tems are also sometimes used. However, all these devices waste energy, dissipate power by friction and diffuse heat.
Fixed-speed pumps draw nearly full horsepower and consume nearly maximum energy full time, regardless of demand. Power requirements for throttled systems drop only slightly even when flow or volume is reduced significantly.
Variable speed devices such as belts, gears, magnetic clutches and hydraulic drives accomplish this function mechanically, but they are costly, bulky, waste power and require high maintenance.
DC adjustable speed drives can provide speed variation. However, DC motors are two to three times the cost of an equivalent-rated AC motor. DC motors are also larger, heav­ier, require more maintenance and are more difficult to operate in chal­lenging environments.
Variable frequency control of AC induction motors provides an economical­ly sound and operationally effective solution for speed control and reduced power consumption. It can also be made responsive to signals from flow sensors, programmable controllers and other control systems. Microprocessor-based AC motor control affords users options that can provide short- and long-term productivity and profitability improvements.
hitachi fig 1 affinity.jpgFigure 1. Variable frequency drives permit users to consume the least amount of power to obtain desired pressure and flow.
Curves Determine Centrifugal Pump Efficiency
In-line valves are often used to regulate flow or pressure in liquid pumping sys­tems. The valve can be a significant source of energy loss by caus­ing a restriction in the flow path, thus increasing the pressure. An AC drive provides more efficient flow control by varying the pump motor speed. By comparing the energy requirements and costs when a throttling device is used for flow control on a centrifugal pump with the power used when an variable frequency drive (VFD) is used to control the same flow, the potential savings become evident.
hitachi fig 2 pump energy savings.jpgFigure 2
The first step is to determine the theoreti­cal load requirements and potential energy savings for the specific application using three interrelated Affinity Laws.
Adding the two heads together creates the system curve, which describes what flow will occur given a specific pressure. Knowing the system curve, the pump manufacturer can select an impeller size to meet the flow requirements specified.
The point where the pump curve and the system curve cross determines the operating point of the system. This system will have only one operating point, so if variable flow is required, something needs to be added.
Flow Control
Not all options are created equal. The typical technique for flow control is the use of a throttling valve. Partially closing the valve adds another restriction, raising the system losses and the system curve. The flow rate will now be determined by the point where the new system curve crosses the pump curve. The amount of energy the system consumes to do this is proportional to the head pressure and the flow rate.
Using a variable frequency drive to control the flow means no additional restriction is added to the piping. Therefore, the system curve remains the same. Varying the speed with a variable frequency drive has the same effect as installing a different-size impeller on the pump: a new pump curve results.
Each flow control method has different lev­els of energy efficiency:
  • Diverting Valve-Flow is diverted from the output of the valve back to the valve input; energy usage is the same, independent of how much output flow is created.
  • Hydrostatic Drive-A variable speed device like the variable frequency drive, but its internal operating losses are higher.
  • Mechanical Drive-A variable belt and sheave device; additional friction and windage losses are created.
  • Eddy Current Drive or Clutch-Uses magnetic coupling to transfer torque at different speeds; the slip losses in the clutch keep it from being a superior performer.
  • Variable Frequency Drive-Has low internal power losses over the speed range.
Using a variable frequency drive in a pumping system provides additional savings because many elements required in a valve-con­trolled system are eliminated or reduced without affecting the function.
Losses in a valve-controlled system occur in the valve and in the additional piping required to bring the valve to a location where it can be adjusted. With the variable frequency drive, there is no valve or valve losses. With no pipe bends required for the valve, the piping losses are also reduced. With the elimination of the pipe and valve losses, a smaller pump can often be used. Users can achieve the same results-flow rates and pressure-with a lower horsepower pump. Significant sys­tem cost savings are realized, providing additional eco­nomic justification for using a variable frequency drive.
Further, microprocessor-based variable frequency drives can perform functions previ­ously handled by programmable controllers, improving process flexibility and further eliminating components and cost.
Choices
Variable frequency drives are available from fractional to 1,000=hp with a wide range of input voltages and options. Since they are designed to operate with standard motors, they can easily be applied to an existing system. However, when choosing a variable frequency drive for a particular system, it is essential to evaluate the product in terms of:
  • Features and functions
  • Ease of installation
  • Ease of operation and maintenance
  • Availability of options
  • Expansion or upgrade capability to meet present and future needs
  • Comprehensiveness of the vendor's application and service offering
  • Among the features pump users should investigate are:
  • Pump Functionality-Features are specifically designed for pumping applications that minimize start-up time and provide a smooth interface for operators.
  • Application Support-Application engineering support is an essential resource for users before, during, and after the installation.
  • Input AC Line Reactors-Most variable frequency drives require some amount of input impedance, and an externally mounted AC line reactor normally satisfies this requirement. It also protects the inverter from line surges and provides a degree of harmonic noise suppression.
  • Output Filters-When an application requires a long cable length between the variable frequency drive and the motor, some type of output filtering is required due to the reflected wave phenomenon that results in damaging high peak voltages at the motor terminals. To protect the motor, users need to verify that several different types of output filtering devices are available. These include output reactors, RLC fil­ters, sine wave filters and filters that reduce or eliminate the high voltages.
  • Other Options-Options such as communication interfaces, RFI filters, etc. may be required to meet the specific needs of the application.
Selection should depend on flexibil­ity, options, service and support critical to the business and operational suc­cess of the control system. The importance of choosing a supplier with the appropriate technical capabilities and expertise in apply­ing variable frequency drives solutions cannot be overemphasized.
The business and operational benefits of implementing the most effective pump con­trol solution are evident. With thorough under­standing of simple principles, examination of the specific application needs and evaluation of options, engineers can gain substantial costs saving and performance advantages.
As energy costs continue to rise, it will become more imperative to find ways to cut energy consumption. Variable frequency drives in pumping applications is a key facet of this effort. Furthermore, with the ongoing develop­ment and enhancement of technologically advanced variable frequency drives, users will have system-critical equipment with the ability to make a larger contribution to oper­ational performance. As an integral part of enterprise-wide systems, variable frequency drives afford users pump control options that save dollars and make sense.
