My previous article in the April issue of Pumps & Systems (read it here) on the use of automated data acquisition systems focused on testing two pumps individually to compare the pumps’ actual performance to the predicted OEM curve for a new pump. The system (PREMS-2A), operating continuously, logs flow, power, pressure, vibration, temperature and other data parameters. Software translates that data into a “pump curves language,” displaying the resultant performance live on the computer screen remotely and continually. As we saw, the actual performance displayed reduced performance, resulting in wasted energy. The clusters of data showed the main flow regions the two pumps operated during the testing. However, on the same plot, there were clusters of data with pump head being oddly out-of-line with the rest of the tracked data. The parting quiz to our readers was to explain the reason why a pump head at certain times was considerably greater than the rest of the logged displayed data. I received feedback from several people on this question, including Lee Ruiz of Oceanside, California: Dr. Nelik, Thanks for your articles. In your April field efficiency case study, it appears that figure 4 (April-17 P&S) is a combination of pump 1 performance in addition to the parallel operation of 1 & 2 operating together. Right on, Lee! That is exactly what the PREMS-2A system picked up: a two-pump operation, resulting in higher total head but not necessarily a proportional increase in flow. This means our system is “friction-dominated,” with elevation head being negligible (see Figure 1).
- Pumps apparently have the same impeller OD trim (judging from the shut-off heads being the same), but significantly reduced flow for pump 2, likely due to opened (worn) clearances
- Economic evaluation of the flow and power change would help justify the upgrade
- The type of system curve is identified (mostly friction, in this case), which will help select new pumps application without costly engineering analysis of the entire system hydraulics
- Clusters of data help identify actual region of pump operation, and the effect on energy/efficiency at such operating flows
