Elimination of micropollutants in biologically treated wastewater has become increasingly important. One reason for this is that contamination of the environment by these substances has now been clearly proven. The regulatory framework in different jurisdictions is expected to be tightened—and threshold values increased—for micropollutants in cleaned wastewater that is discharged into the aquatic environment. Most of the currently applied process combinations do not include membrane filtration, although this process is often advantageous, in particular with respect to the issues of multi-resistant germs, antibiotic drugs and microplastic particles that can come from a wide variety of sources. Today, a combination of powdered activated carbon and subsequent sand filtration is mainly used to eliminate micropollutants. This process can reduce trace substances like drug residues in the effluent of a wastewater treatment plant.
How to separate micropollutants with an innovative membrane process
Microdyn-Nadir
06/01/2017
Image 1. A municipal wastewater treatment plant in Hünxe, Germany, was the site of a test trial to remove micropollutants using ultrafiltration membranes. (Courtesy of MICRODYN-NADIR)
