Real-time monitoring software and trained support staff provided early warning of critical equipment issues and prevented costly faults.
11/13/2014
Predictive monitoring of critical rotating and non-rotating equipment is important for successful plant operation. Two end users benefited from this type of real-time monitoring of their critical assets. They were alerted to small abnormalities that could have escalated to expensive interruptions, helping maintenance personnel take a more preventive approach.
Recirculation Valve
In early October 2013, an analytics software solution detected a potential problem on the recirculation valve of a feed pump at a combined-cycle power plant. Given the current operating conditions, the software predicted the difference between the actual recirculation valve position and the demanded recirculation valve position to operate around 5 percent. However, the actual values were as high as 8.5 percent. The software support team discussed the issue with plant personnel on the next weekly call. During the next several weeks, the plant’s employees and the software company’s support team jointly monitored the issue. In late October, the performance of the valve began to deteriorate rapidly, with differences between the actual valve position and the demanded valve position reaching values as high as 20 percent. The underlying cause was found to be a failed converter on this valve. Because of the early warning of this valve failure, employees had an opportunity to plan their maintenance action. Plant personnel replaced the converter. If this issue had not been corrected in a timely manner, it could have tripped the pump and caused unplanned downtime and an unexpected loss of production. Any unforeseen interruption in plant processes costs money in lost product and requires personnel to find and correct the problem.Lube Oil Tank Level Sensor
In mid-August 2013, monitoring software at work on an oil and gas platform detected an increase on a combustion turbine’s lube oil tank level from its normal operating level of 530 millimeters to values above 590 millimeters. Experts from the software provider company notified the end user of these changes during their regular weekly call (see Figure 1).
