At the end of May 2014, the U.S. Department of Energy (DOE) released the Final Rule that amends the regulation for integral horsepower motors. Until the rule takes effect June 1, 2016, motor manufacturers will continue to operate under rules from the Energy Independence and Security Act (EISA), which took effect in December 2010. This means that almost all low-voltage, three-phase motors sold for use in the U.S. will need to be premium efficiency per National Electrical Manufacturers Association (NEMA) MG 1-2014, tables 12-12 and 20B. Additionally, 56-frame enclosed motors, including those with 56J pump mounting, are covered. Motors with close-coupled pump mounting in JM, JP and West-Coast configurations will now move from energy efficiency (table 12-11) to premium efficient levels. All types of vertical hollow-shaft and solid shaft P-base motors also will be required to be premium efficiency. Only submersible motors will be exempt.
09/16/2015
