MORTON GROVE, Ill. (Jan. 31, 2012)
Bell & Gossett's new Ultra Setter line of pressure-independent control valves feature a unique design that provides full stroke modulation while maintaining 100 percent authority at all times. Together with a technologically advanced GPM adjustable dial, the new Ultra Setter Control Valve provides more accurate flow control, eliminates valve hunting, and improves energy efficiency in the entire HVACR system.
This unique valve provides a more accurate flow that significantly reduces energy consumption and improves system efficiency.
Other features of the Ultra Setter Control Valve include:
  • Field-adjustable, lockable GPM dial allows user to set and change maximum flow rate quickly and easily
  • Full stroke modulation at all times
  • Always provides 100% authority, ensuring excellent control
  • Maintains desired flow rate despite fluctuations in system pressure
  • Eliminates valve hunting
  • Combination valve reduces first costs and more accurate flow control lowers life cycle costs
  • Sizes from ½” to 2”
  • Flow rates from 0.13 to 37 GPM
Xylem is a global water technology provider, enabling customers to transport, treat, test and efficiently use water in public utility, residential and commercial building services, industrial and agricultural settings. The company does business in more than 150 countries through a number of product brands, and its people bring broad applications expertise with a strong focus on finding local solutions to the world’s most challenging water and wastewater problems. Launched in 2011 from the spinoff of the water-related businesses of ITT Corporation, Xylem is headquartered in White Plains, N.Y., with 2010 annual revenues of $3.2 billion and 12,000 employees worldwide.
