The University of Idaho built a mobile water treatment platform to demonstrate a scalable, carbon-neutral technology.
AutomationDirect.com
09/20/2017
The purpose of the research wastewater treatment process trailer is to test water treatment technologies (see Image 1). Specifically, this nine-ton, 40-foot-long process trailer confirms the possibility of renewable water reuse through water contaminant destruction, water sterilization and other water treatment tools. The system can also use biochar from biomass energy production to clean water. The system removes nutrients and recovers phosphorus when treating dirty water to supply reusable water. Reactive water filtration is used with functionalized biochar as a catalyst, with ozone used for catalytic oxidation.
Biochar & Catalytic Oxidation
An important part of this process is the biochar catalyst, which is like activated charcoal used in inline water filters. When looking at biochar science, there are eco-friendly, sustainable advantages. Since it is recovered from plant life and not fossil fuels, the biochar biomass energy is carbon neutral. Also, the biomass carbonization process can produce liquid fuels, and the heat created during production of biochar can generate energy. Because the biochar helps trap water and nutrients in the soil, agricultural productivity can be increased. Part of the process includes catalytic ozone oxidation, which provides destructive removal of many organic contaminants in wastewater, such as hormones and antibiotics. This oxidation also can destroy microbial life such as bacteria, viruses and prions.
Equipment Process Steps
The portable water treatment process trailer was built on a 40-foot flatbed trailer and includes a 20-foot metal shipping container housing the instrumentation and process controls. The container also includes the pumps, valves, ozone generator, air compressor and air dryer used in the process. Sample ports, testing equipment and a control enclosure are also housed in the container. This complete water-treatment process training and research platform includes chemical dosing, main fluid flow, and air and ozone fluid flow systems. The external process control system includes a pair of interlaced lime green plug-flow reactors that perform the treatment, and a pair of blue catalytic filter towers (see Image 1). Each 45-foot plug-flow reactor is followed by a catalytic filter tower—a self-cleaning moving bed reactive sand filter. Small doses of functionalized biochar and ozone are metered into the first reactor, with sand in the first filter made highly reactive to remove trace contaminants. Precise amounts of ozone and metal salts are pumped into the second reactor effluent for high efficiency water polishing. At the output, the byproducts, phosphorus and nitrogen bound to biochar, are recovered for use as fertilizer. The effluent then moves through the second sand filter where the water is polished again. The output of this filter is clear, clean water.
Scalable Control Hardware
Not only can the process be scaled, the control system can as well (see Image 2). The control enclosure, housing the programmable logic controller (PLC) and human machine interface (HMI) can handle a much larger process. Increasing the size and duplicating some of the power distribution components, motor and drives could enable pumping and treating millions of gallons of effluent per day. The process is automated with the PLC for motor control, opening and closing valves, operating pumps, and metering biochar and ozone. The PLC also monitors flow and level for process signal control and sampling operations. The process treatment sample sensors included pH, redox, dissolved ozone, head-loss, turbidity and total organic carbon. The process control hardware also provides supervisory control and data acquisition for the process trailer, and includes wireless streaming capability. The controller technology offers a modular, rack-based system with extensive discrete, analog and specialty I/O module options. The high-performance CPU has the memory, I/O capacity, communication ports and scan times needed for the current process, and for a larger scaled-up process.Data Logging
Data logging is a vital part of this process and the related research activities. Significant amounts of data are logged using the controller and the HMI. The controller provides up to 32 GB of data storage using a standard microSD card. Users access the controller’s built-in web server using any browser to view, download or delete data log files.
